wiringpi hangs
Posted: Fri Mar 10, 2017 7:03 am
by Danilk
The debugger shows that the "import wiringpi" takes place, but the procedure initialize wiringpi.wiringPiSetup() hangs and nothing happens
Re: wiringpi hangs
Posted: Fri Mar 10, 2017 8:03 am
by texy
how have you installed wiringpi? Seems there are a few different methods/forks :
viewtopic.php?f=32&t=146173&p=1123887&h ... i#p1123887
Texy
Re: wiringpi hangs
Posted: Fri Mar 10, 2017 8:44 am
by Danilk
sudo apt-get install wiringpi
gpio -v
gpio version: 2.44
Copyright (c) 2012-2017 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Rev 1.2
* This Raspberry Pi supports user-level GPIO access.
sudo pip install wiringpi
Requirement already satisfied (use --upgrade to upgrade): wiringpi in /usr/local/lib/python2.7/dist-packages
sudo pip install wiringpi2
Requirement already satisfied (use --upgrade to upgrade): wiringpi2 in /usr/local/lib/python2.7/dist-packages/wiringpi2-1.1.1-py2.7-linux-armv7l.egg
Re: wiringpi hangs
Posted: Fri Mar 10, 2017 10:09 am
by texy
can you post the complete code so that others can attempt to replicate the problem. Also how old is your Raspbian OS?
Re: wiringpi hangs
Posted: Fri Mar 10, 2017 10:27 am
by Danilk
import wiringpi
wiringpi.wiringPiSetupGpio()
SSRPwm0=12
SSRPwm1=13
wiringpi.pinMode(SSRPwm0, 2)
wiringpi.pwmWrite(SSRPwm0, 512)
wiringpi.pinMode(SSRPwm1, 2)
wiringpi.pwmWrite(SSRPwm1, 256)
update/upgrade raspbian 09mar2017
Re: wiringpi hangs
Posted: Sat Mar 11, 2017 10:06 am
by Danilk
