Dynamic Timer Logic
Posted: Mon Feb 20, 2017 8:44 pm
by biosboy4
I am trying to sound an alarm whenever my laser/lightsensor is blocked for more than 60 seconds. What might this logic look like?'
I haven't been able to make a while loop work with and if and a sleep command.
I need it to be something like:
if sensor is blocked, count 60 seconds and sound the alarm.
However, I need the value of the lightsensor to be able to reset the counter.
Thanks for your direction!
biosboy4
Re: Dynamic Timer Logic
Posted: Mon Feb 20, 2017 9:30 pm
by pcmanbob
Hi.
So I assume you are monitoring a GPIO input so you know when your laser/lightsensor is blocked.
so when the input goes high ( assuming high is alarm state) you run this .
were GPIO.input(x) is your monitoring GPIO input.
alarm = gpio.input(x) #this is the pin you are using to monitor your sensor goes high on alarm
count = 0
while alarm = 1:
	if count = 60:
		print "alarm"
		alarm = 0
	else:
		count = count + 1
		time.sleep(1)
so while the alarm = 1 it will check to see if count = 60 if it does it sounds the alarm and exits the loop by setting alarm = 0
but if count is less than 60 then it adds 1 to the count , sleeps for 1 sec then reads the GPIO input again , if its still 1 the loop continues, if how ever the input is now 0 the loop will end.
please not I have not tested this its just off the top of my head.
Posted: Tue Feb 21, 2017 12:02 am
by biosboy4
I think you're awesome, thank you!
I'm trying it right now. :)
Edit: I am getting a random syntax error at the equal sign (alarm = 1) Thanks for you help! Here is the code:
from gpiozero import LightSensor
from time import sleep
import pygame
ldr = LightSensor(4)
pygame.init()
pygame.mixer.init()
buzz = pygame.mixer.Sound('/home/pi/Downloads/Buzz2.ogg')
length = buzz.get_length()
alarm = gpio.input(4)
alarm
count = 0
while   alarm = 1:
        if count = 60:
        buzz.play()
        sleep(10.1)
        buzz.stop()
        alarm = 0
    else:
        count = count + 1
        time.sleep(1)
        alarm = 0
Posted: Tue Feb 21, 2017 5:52 am
by ghp
use "while alarm == 1:" to check for the value.
And the identation does not look perfekt the next line.
You have:
while   alarm = 1:
        if count = 60:
        buzz.play()
Most possibly it should be
while   alarm == 1:
    if count == 60:
        buzz.play()
Regards,
Gerhard
Posted: Tue Feb 21, 2017 10:41 am
by pcmanbob
biosboy4 wrote:I think you're awesome, thank you!
import pygame
pygame.init()
pygame.mixer.init()
alarm
count = 0
while   alarm = 1:
        if count = 60:
        buzz.play()
        sleep(10.1)
        buzz.stop()
        alarm = 0
    else:
        count = count + 1
        time.sleep(1)
        alarm = 0
I did say it was only an example and your version is not correct with the spacing either, and you did not do the up date of alarm as I showed in my example.
so I have reworked your example code, try this.
count = 0
while alarm == 1:
		if count == 60:
			buzz.play()
			sleep(10.1)
			buzz.stop()
			alarm = 0
		else:
			count = count + 1
			time.sleep(1)
As before I have not tested this
Posted: Tue Feb 21, 2017 4:50 pm
by biosboy4
I really appreciate all the help guys. However, due to my absolute newness to programming, I'm having a difficult time following.
Basically, I am tying to make the alarm sound ONLY when the lightsensor is blocked for a solid/consecutive 60 seconds.
Here is my current draft of code:
import pygame
import RPi.GPIO as gpio
pygame.init()
pygame.mixer.init()
sleep (0.1)
if ldr.value < 0.8:
    alarm = 1
else:
    alarm = 0
count = 0
while alarm == 1:
      if count == 7:
         buzz.play()
         sleep(10.1)
         buzz.stop()
         alarm = 0
      else:
         count = count + 1
         sleep(1)
Thanks again guys; I apologize for my noobishness. This is the first code I have ever tried to write, lol.
Posted: Tue Feb 21, 2017 7:49 pm
by biosboy4
It seems like it would be a lot easier like this, right? (Although it isn't working, the shell is just chillin when I run it..)
import pygame
pygame.init()
pygame.mixer.init()
sleep (0.1)
while ldr.value < 0.9:
     if ldr.value < 0.9:
        sleep(7.1)
        buzz.play()
        buzz.stop()
Posted: Tue Feb 21, 2017 9:01 pm
by pcmanbob
Ok seeing as you could not get the code to work a have tested this and it works as per your request.
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(4, GPIO.IN)
GPIO.setup(18, GPIO.OUT)
GPIO.output(18, GPIO.LOW)
while True:
	alarm = GPIO.input(4)
	print "alarm = " , alarm
	count = 0
	time.sleep(1)
	while alarm == 1:
		print "count = " , count
		if count == 10:			# set number of seconds delay before alarm sounds
			print "alarm on"
			GPIO.output(18, GPIO.HIGH)
			time.sleep(5)		# set how long alarm souns for
			print "alarm off"
			# for the alarm to cycle while ever the sensor input is high un-coment the line below
			#alarm = 0
			# for the alarm to only sound once while ever the sensor input is high un-coment the lines below
			count = count + 1
		else:
			count = count + 1
			time.sleep(1)
So this code is set so that it runs the alarm sequence when the input on GPIO 4 goes High.
so the code is tested and works in both modes.
if you want the alarm to only sound once for each input trigger then leave the code as it is, but if you want the the alarm to sound then wait for the prescribed time then sound again then you need to un-coment the line line and comment out the lines below it.
Posted: Tue Feb 21, 2017 9:46 pm
by biosboy4
This code seems to be working except that the counter doesn't ever reset. Could it be too much ambient light on the sensor?
import time
import pygame
pygame.init()
pygame.mixer.init()
while True:
   count = 0
   time.sleep(1)
   while alarm == 1:
         print "alarm on"
         buzz.play()
         sleep (14.7)
         buzz.stop()
         print "alarm off"
         alarm = 0
         count = count + 1
      else:
         count = count + 1
         time.sleep(1)
Posted: Tue Feb 21, 2017 10:48 pm
by pcmanbob
you obviously did not read my post and understand it, you can't have both these lines set.
         alarm = 0
         count = count + 1
how simple does it have to be, these are the 2 options choose which one you want to use.
you either use it like this
         #alarm = 0
         count = count + 1
or you use it like this
         alarm = 0
         #alarm = GPIO.input(4)
         #count = count + 1
Note the different # placings
and finally the code works when tested with a switch if you sensor is high all the time then no it will never reset, I suggest you test your sensor it see if it ever goes low.
Posted: Wed Feb 22, 2017 6:46 am
by rpdom
pcmanbob wrote:you obviously did not read my post and understand it, you can't have both these lines set.
         alarm = 0
         count = count + 1
Well, you can have both those lines set, but the "alarm = GPIO.input(4)" will make the "alarm = 0" redundant. You only really need to do as the instructions say and comment or uncomment the last two lines shown there.
