think there are two areas where your script needs to be improved.
One point is the arrangement of code
if run == False:
os.system("nohup /home/pi/radio.sh &>/dev/null &")
time.sleep(4)
print()
run = True
time.sleep(0.2)
if run == True:
os.system("sudo pkill mplayer")
run = False
if the first "if run == False"- block, the run-variable is set to True. Which immediately results in the execution of the " if run == True:"-Block. So your mplayer gets stopped immediately after a start.
Here an 'else if '-condition for the second block would help.
The other point is the handling of button pressed-event. Think you want to achieve something like 'when button pressed first time, then switch on, when button pressed second, switch off' The unspoken event in between is to check for a button released condition.
Here a proposal for a state based approach. I used GPIO 3, change this back to your GPIO used. The quite long delay(0.1) is to debounce the button and avoids excessive cpu usage.
import RPi.GPIO as GPIO
import time
debug = True
BUTTON_GPIO = 3
GPIO.setmode(GPIO.BCM)
GPIO.setup(BUTTON_GPIO, GPIO.IN)
# the signals used to detect button pressed/released signals.
# here: button is connected to gnd (active is a low signal)
PRESSED = 0
RELEASED = 1
# the state enumerations are defined here as 'constants'. The development environment I use
# allows for variable lookup and thus avoids problem by misspelling
START = 'start'
B0_RELEASED = 'B0_RELEASED'
B0_PRESSED= 'B0_PRESSED'
B1_RELEASED= 'B1_RELEASED'
B1_PRESSED= 'B1_PRESSED'
state = START
nextState = None
while True:
time.sleep(0.1)
nextState = None
c = GPIO.input(BUTTON_GPIO)
if state == START:
if c == RELEASED:
nextState = B0_RELEASED
elif state == B0_RELEASED:
if c == PRESSED:
nextState = B0_PRESSED
print("do your switch ON radio action here")
elif state == B0_PRESSED:
if c == RELEASED:
nextState = B1_RELEASED
elif state == B1_RELEASED:
if c == PRESSED:
nextState = B1_PRESSED
print("do your switch OFF radio action here")
elif state == B1_PRESSED:
if c == RELEASED:
if debug == True:
if nextState != None:
print("{state:s} --[ {c:d} ]--> {nextstate:s}".format(state=state, c=c, nextstate=nextState))
state = nextState
Regards,
Gerhard
