raspberrypiguy1
Python WiFi communication between 3 Pis
Wed Feb 08, 2017 6:04 pm
Hi folks,
Got a small query surrounding the use of WiFi as a medium of communication between 3 Raspberry Pis. Essentially I am creating a lidar system that has 3 independent subsystems, each controlled by a Pi. The subsystems are: 1) stepper motor control for rotation 2) distance measurement 3) touchscreen UI. All of these Pis need to be able to ideally communicate with one another and not be bogged down by one of them being the server etc. An overview of the flow of data can be found attached.
Also note that the data is just text (distance and rotational position), but it would be quite neat to extend the project to use a Pi camera as well, so preferably images would be able to be sent over the network between the Pis too.
What is the best way to network 3 Pis in Python that would facilitate both text and image communication?
Matt
Flow of Data
Matt, The Raspberry Pi Guy YouTube channel, author of Learn Robotics with Raspberry Pi, available now: http://mybook.to/raspirobots, Computer Science & Electronics Undergraduate at The University of Edinburgh
kusti8
Re: Python WiFi communication between 3 Pis
Wed Feb 08, 2017 7:51 pm
Easiest way would be to make one be a AP and have them talk to each other with sockets or mqtt or something. It wouldn't get bogged down at all by traffic since it's pretty powerful.
Wed Feb 08, 2017 8:09 pm
How closely located are they? Because up to 100m is easiest with a cat5 cable and a small 5-port 100Mbps switch (which cost about a tenner including VAT+P&P). The ones I use are: https://www.amazon.co.uk/TP-LINK-TL-SF1 ... B000FNFSPY
If you give one RPi an RTC board it can serve the time of day to the other two (the NTP set-up for that is trivial). If you also run dnsmasq on there then the master machine hands out the IP addresses to the other two (so everyone can find the master). Run avahi-daemon and everyone can find every other machine with $(hostname).local The side effect of that is that if you plug a laptop into the switch for maintenance then it gets an IP address assigned from the same dnsmasq server. It's then easy to find all the machines on your small self-contained LAN.
You can do it with WiFi with one master machine running hostapd and dnsmasq as a WiFi AP, but you won't gain much over a wired set-up. Again the master machine can have the RTC so that all the clocks can sync to it. Again your laptop can be used to connect to the WiFi "mesh". You only need WiFi if the machines can move. If they're screwed down use wired.
MQTT is clearly the best choice for your command & control messages, that's what it was designed for by Dr Stanford-Clark and others.
Return to “Python”
