daveyman123
python and bluetoothctl
Sat Jan 07, 2017 11:16 pm
How would I go about using BluetoothCTL in a python script
I want to write a script that connects a bluetooth device automatically
Thanks,
DM123
Douglas6
Re: python and bluetoothctl
Sat Jan 07, 2017 11:27 pm
1. You could use pexpect to control bluetoothctl from Python.
2. You could use subprocess to run the following bash command:
echo -e "connect AA:BB:CC:DD:EE \nquit" | bluetoothctl
3. You could run the previous command from a bash script and skip Python altogether.
daveyman123
Sat Jan 07, 2017 11:40 pm
Thank you for the info. I assume ill use python since im trying to learn it for a class im taking soon.
You wouldnt also happen to know an easy way with python to my raspberry pi with a python script?
I would like to use python to connect from a windows to the Pi and then run the script.
Thanks,
DM123
daveyman123
Sun Jan 08, 2017 12:21 am
Douglas6 wrote:1. You could use pexpect to control bluetoothctl from Python.
I ended up using this code to connect. Now I need to somehow use pacmd to connect pulseaudio
from sh import bluetoothctl
mac = "AA:BB:CC:DD:EE"
bluetoothctl("connect",mac)
Only problem is that although it should work theoretically it just hangs up... I have a lot to learn
Douglas6
Sun Jan 08, 2017 1:52 am
I'm afraid I'm not familiar with the 'sh' module. Best of luck!
yash012
Tue Mar 21, 2017 6:56 am
I know this is a very old post but when i used this command it return Glib critical source ID was not Found while attempting to remove it.
if you can tell me what to do about this.Thank you.
Douglas6
Tue Mar 21, 2017 7:23 am
You'll need to be more specific. What command is giving you the problem?
yash012
Tue Mar 21, 2017 7:31 am
when i entered
echo -e "connect 77:XX:XX:XX:XX  \nquit" | bluetoothctl
gives me Glib Critical source ID 24 was not found, i then tried "scan on" and "list" but it gave me same error but with Source ID 29 not found or source ID 25 not found
yash012
Tue Mar 21, 2017 7:33 am
i was trying the bash command you suggested to connect to bluetoothe device
Return to “Python”
