markpipython
Pi Python script stops after 3-4 hours
Mon Dec 26, 2016 8:06 pm
Hi I'm new to Python and have made a simple script to record an integer value to a url (saving to Mysql database).
This script will run for 3 to 4 hours without a hitch, but then is stops responding!
Can anyone help, please. Thank you
Script
____________________________________________________________________________
#!/usr/bin/python
import requests
import time
import math
url = 'http://castle.remote-data.net/insert.php?one=89&two='
print 'Monitoring a variable every minute...'
while True:
result = 250 // Using value of 250 to test
print 'Variable: %i' % (result)
data = url+str(result)
r = requests.get(data, stream=True)
print (r.status_code) // We should get back '200'
time.sleep(60.0) // Wait one minute
Errors after it stops working
File "atod.py", line 38, in <module>
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 60, in get
return request('get', url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 49, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 457, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 569, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 407, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', BadStatusLine("''",))
paddyg
Re: Pi Python script stops after 3-4 hours
Tue Dec 27, 2016 12:45 am
you could put that bit inside a try, except block and check whether you've got a ConnectionError (or some other one I suppose). Maybe twiddle your fingers for a bit then try again.
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
alexeames
Tue Dec 27, 2016 5:42 pm
paddyg wrote:you could put that bit inside a try, except block and check whether you've got a ConnectionError (or some other one I suppose). Maybe twiddle your fingers for a bit then try again.
Yep. I'd guess it's bombing out the first time it fails to connect to the url. Letting it fail gracefully with try: except: should work. :D
Alex Eames RasPi.TV, RasP.iO
markpipython
Thu Dec 29, 2016 9:48 pm
Thank you
I've used the 'try' and 'except' as suggested and been working fine now for a couple of days...
try:
print ('Light: %i & Result: %i' % (result, r.status_code))
except ConnectionError as e:
print e
r = "No Response"
Return to “Python”
