Code for a Pi Zero Sound Player
Posted: Fri Nov 11, 2016 7:34 am
by saulton7
Hey all,
I am new to Pi's I have used Arduino before but frankly my coding abilities are lacking/very rusty.
I am trying to make a Pi zero that is powered from and outside power supply of 5V and does three things
-Play a sound file played on startup
-Have a safe shutdown sequence activated by button
-Have a sound file played at the press of a button
I already figured out how to get the sound to play on startup by adding the command in /etc/rc.local but I am having trouble getting the shutdown script to run as well. I was curious if there was a way to write a single script that could do all of these things, if so that would be awesome. Any and all help is much appreciated. Thanks!
Re: Code for a Pi Zero Sound Player
Posted: Fri Nov 11, 2016 8:01 am
by saulton7
import RPi.GPIO as GPIO
import time
import os
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7, GPIO.IN)
GPIO.setup(11, GPIO.IN)
aplay /etc/sound/Start.wav
while True:
if (GPIO.input(7)):
os.system("sudo shutdown -h now")
if (GPIO.input(11)) == False):
aplay /home/pi/Music/Sounds/Fire1.wav
time.sleep(0.1);
This is what I got so far
Posted: Fri Nov 11, 2016 10:49 am
by elParaguayo
You could certainly have a script that plays a sound when it starts and then listens for button presses.
The best way to learn (in my own view) is to:
- try some code
- change it
- inevitably cause an error
- search for the error
- see if I can fix, if I can, move on until I hit #3, if I can't, then I ask for help.
- repeat until everything works!
So, you've got some code already which is a great start (much better than just asking someone to write it). So what happens when you run it? What error messages do you get?
I'll give you a clue for starters, this line:
will cause an error. That may work in a shell script (and I'm guessing you added it straight to /etc/rc.local) but it's not a python command so you'll need to have a see how to run shell commands in python (hint - you've done it elsewhere in your code).
As for the buttons, you may want to take a look at gpiozero which simplifies some of this.
Good luck and please post more again if you get stuck.
Posted: Fri Nov 11, 2016 11:20 am
by saulton7
import os
from time import sleep
os.system('mpg123 -q start1.mp3 &')
while True:
if (GPIO.input(7)):
os.system('sudo shutdown -h now &')
if (GPIO.input(11)):
os.system('mpg123 -q Fire1.mp3 &')
break
time.sleep(0.1)
Posted: Fri Nov 11, 2016 11:24 am
by saulton7
elParaguayo wrote:You could certainly have a script that plays a sound when it starts and then listens for button presses.
- try some code
- change it
Thanks for the help, ive worked at it some more and this batch of code sort of works. I get the startup sound to play. and I can get one of the two conditions to work. As in I press one of them and then the script ends and I would have to restart it. Is there a way to keep the script working even after i press one of the buttons? I am specifically using this code to have a raspberry pi zero play sounds in a Prop laser rifle. where upon powering up there is a played sound, followed by the rifle making a firing noise whenever the trigger is pressed. With the shutdown button being used for safe shutdown of the Pi before main power being cut off. So how would I keep the script running while also taking into account the need for debouncing of the inputs?
Thanks again
Posted: Fri Nov 11, 2016 12:53 pm
by elParaguayo
Take the "break" line out (it exits your loop).
You may also want to use a print statement or something else instead of the shutdown command while you're testing your script!
Posted: Fri Nov 11, 2016 8:58 pm
by saulton7
Removing the break produces the same result. Any thoughts?
Posted: Sat Nov 12, 2016 7:13 am
by elParaguayo
Is it exiting cleanly, or is there an error message?
Posted: Tue Nov 15, 2016 6:07 am
by saulton7
When I remove the break, there is sort of an error message as in the screen show multiple prints of "shutdown" and the sound for the laser rifle starts to fire erratically. I suspect it has something to do with the inputs and the bouncing effect.
Posted: Tue Nov 15, 2016 6:39 am
by elParaguayo
Indeed. There are plenty of examples on the forum of debouncing.
I suspect the gpiozero module has this built in.
Posted: Tue Nov 15, 2016 7:23 am
by saulton7
import os
from gpiozero import Button
from subprocess import check_call
from signal import pause
def shutdown():
#check_call(['sudo', 'poweroff'])
print ('SHUT')
def laser():
# os.system(mpg123 -q Fire1.mp3 &')
print ('BANG')
shutdown_btn = Button(17, hold_time=2)
shutdown_btn.when_held = shutdown
laser_btn = Button(4, bounce_time=200)
laser_btn.when_pressed = laser
pause()
Posted: Tue Nov 15, 2016 7:25 am
by saulton7
This is my try at using GPIOzero. It has been working a little bit better. As the code runs now, I can press the shutdown button and produce the SHUT action as many times as I want, but the BANG action will only work once and then no more. Any help appreciated!
I figure that I need to create a loop of sorts, but my knowledge and skill is very limited. Where should I start?
edit : I am very stuck i clearly know nothing about loops
Posted: Tue Nov 15, 2016 12:09 pm
by elParaguayo
Are you using an old version of the software?
A similar issue was reported here:
http://raspberrypi.stackexchange.com/qu ... -only-once
Posted: Thu Nov 17, 2016 6:09 am
by saulton7
I updated everything and the same events are occurring. Can anyone replicate this on their own Pi's? I'd like to solve this soon please and thanks
