frankenberry
Run Python Script at Startup
Wed Oct 26, 2016 2:10 am
I'm sure this has been explained ad nausem, however the post explaining how to do it eludes me...
I have a python script I want to run in the background when the raspberry boots up. The script I run requires a .json file to be present in the folder that the script command runs from (as far as I understand it). The .json file allows me to write to a google sheets document.
What is the most robust solution to the problem?
Location of python file:
/home/pi/level1/level2/
I can run the file with the following command:
(sudo python /home/pi/level1/level2/Python/Example.py) $
What do I do now?
Thank you
Return to “Python”
