Bianco
Running a Python script from a webpage
Tue Oct 25, 2016 4:18 pm
I made a script which opens and closes my blinds depending on sunrise dans sunset.
Works great.
I would also like to be able to open or close a blind manually during the day from any computer or smartphone (from a webpage served by the Pi).
For this, I'm willing to create three (up, stop, down) scripts per blind but I need your help to build a webpage and create link that will launch the scripts.
I have Apache installed and the demo page tells me "It works!" but that's it, I have no skill in php, html or server stuff.
So what's the easiest way for me to achieve the objective?
scotty101
Re: Running a Python script from a webpage
Tue Oct 25, 2016 4:48 pm
You'll need some HTML skills at the very least.
I've integrated python scripts with a simple web interface using Flask. Some links below to a flask tutorial and two projects I've created.
https://blog.miguelgrinberg.com/post/th ... ello-world
https://github.com/scotty3785/pi_tv_rem ... _remote.py
https://github.com/scotty3785/python-bl ... web-app.py
There is also this
https://github.com/dddomodossola/remi
I haven't used it but I believe the concept is to create a simple UI from your application without needing to write any HTML.
davef21370
Tue Oct 25, 2016 4:49 pm
Google webiopi.
Dave.
Apple say... Monkey do !!
B.Goode
Tue Oct 25, 2016 5:08 pm
Another forum contributor @penguintutor has an example using the bottle Python library module here: http://www.penguintutor.com/raspberrypi/pi-power
Bianco
Tue Oct 25, 2016 8:36 pm
Are you sure I need flask?
I'm not developing a Python web app, I just want to lauch the script (wich does some magic calculus and send a few bytes to a GPIO) from the page. I don't need do display any interactive feedback or anything fancy.
This seens awefully simple and yet you come up with complicated solution requiring hours of reading. I was hoping for a <A href="script.py"> tag or something that simple. There's nothing like that?
tom.slick
Tue Oct 25, 2016 10:16 pm
add a button to this
<?php
$command = escapeshellcmd('script.py');
$output = shell_exec($command);
echo $output;
scotty101
Wed Oct 26, 2016 8:21 am
Bianco wrote:Are you sure I need flask?
Mainly agree, but when you decide that it might be nice to have some interaction or some feedback from your script, flask will make it much easier. I found flask to have a very short learning curve (certainly for the basics) and it takes very few lines of code to make it work.
Of course, this is just my own opinion and there are methods that will work if you are unwilling to learn a new skill. Nothing comes for free.
B.Goode
Wed Oct 26, 2016 8:56 am
You don't need flask.
If I had known you did not want to read anything I would not have gone to the trouble of writing a reply.
Return to “Python”
