vikash23
python function code for blink LED issue
Sat Oct 22, 2016 9:59 pm
I am trying to blink an LED using the function.
Below is my code
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(11, GPIO.OUT)
speed = raw_input ("Enter length of each blink (second):")
times = raw_input ("Enter total number of times to blink:")
print "Speed:" , speed
print "Times:" , times
def blink(speed,times):
while len(times)== 1:
GPIO.output(11,1)## Switch on pin 11
time.sleep(speed)## Wait
GPIO.output(11,0)## Switch off pin 11
print "Done"
return
GPIO.cleanup()
i get speed and time by user input and use blink function.
i get output for the speed and time but my LED is not blinking
I checked the connection using a simple LED blink program and it works.
I think i have made a mistake with while loop. can any one please help me to resolve.
zmd
Re: python function code for blink LED issue
Sun Oct 23, 2016 6:16 am
You are defining blink function but you are not calling it.
Additionally, time.sleep() function requires parameter as an int (not str). You need to convert str parameters that you get from the user to int in order to call it properly (you can use int() function for converting)
Next time please use code tag to format your code. It is not indented. It is hard to follow in this form.
Bottersnike
Sun Oct 23, 2016 8:50 am
I'm on my phone so I can't test this, but I think the following should work:
import time
speed = input("Enter length of each blink (second): ")
times = input("Enter total number of times to blink: ")
print "Speed:", speed
print "Times:", times
def blink(speed, times):
    for i in range(times):
        time.sleep(speed / 2)## Wait
    print "Done"
    return
blink(speed, times)
GPIO.cleanup()
What I changed:
  • I replaced the raw_inputs with inputs so that it became an integer.
  • I replaced the while loop with a for loop so that it only loops n times.
  • I made it sleep for speed/2 so that the length of the whole pulse lasted for speed.
  • Called blink
There are a few more edits that I need to make but my phone isn't working. I'll get them in in about four hours from now.
Micro:Pi is an (almost) fully fledged IDE for programming a BBC Micro:Bit using C++. Go check it out at https://bottersnike.github.io/Micro-Pi
elParaguayo
Sun Oct 23, 2016 9:02 am
Unless I'm missing something, you've both defined a "blink" function, but never called it.
Given that you seem to only want to run the function once after getting the inputs, I don't think it needs to be a separate function at all.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
vikash23
Sun Oct 23, 2016 7:17 pm
Thanks all for your reply.
I am sorry as I was new to the forum and I am not aware of how to use code tag.
I forgot to call the blink function
But my intention is to use the blink function using a while loop.
is for loop a must when using a function ? why can't i get the times as input and use while loop.
Example:
times = 5
while no of times is less than 10 do the below function.
B.Goode
Sun Oct 23, 2016 7:52 pm
No.
tom.slick
Sun Oct 23, 2016 9:20 pm
Bottersnike wrote:I'm on my phone so I can't test this, but I think the following should work:
import time
    print "Done"
    return
blink(speed, times)
GPIO.cleanup()
What I changed:
  • Called blink
It's not wise to use input with python 2. At the input prompt if you enter this your user folder gets deleted (so DON'T really try it).
eval("__import__('shutil').rmtree('/home/pi')")
instead use raw_input and then cast to the value you need
value = raw_input("Enter a number:")
value = int(value)
print value, type(value)
value = raw_input("Enter a decimal number:")
value = float(value)
I know it will only be an issue if someone want to do something malicious, but why start a bad habit.
vikash23
Sun Oct 30, 2016 9:59 pm
I have tried the blink LED using while loop and for loop.
Now I am trying to interface HMC6352 to pi using I2C.
While using i2C detect on SMbus 1 i found address 21 which is 0010 0001 in binary.
But on the datasheet it says 0x42 for write (0100 0010)
0x43 for read (0100 0011)
basically the binary value of 21 is left shifted 1 and the last value 0 or 1 determines it is read or write to slave device..
datasheet says use command 0x41 to get data.
below is the code which i tried and modified from understanding Arduino programming
import smbus
import time
cmd = 0x41
DEVICE_ADDR = 0x21
bus = smbus.SMBus(1)
def data2():
data1 = bus.read_byte_data(DEVICE_ADDR, cmd)
data3 = bus.read_byte_data(DEVICE_ADDR, 1)
data4 = bus.read_byte_data(DEVICE_ADDR, 2)
d=(data3<<8)+data4
d=d/10.0
return d
while True:
db=data2()
print db
time.sleep(1)
please ignore improper variables as i want to do it quick. below is the output which i got. when i turn my accelerator the code breaks and shows some error.
7.1
77.1
77.1
77.1
77.1
77.1
77.1
77.1
51.4
51.4
77.1
77.1
77.1
77.1
77.1
77.1
77.1
77.1
77.1
77.1
77.1
0.0
77.1
77.1
77.1
File "/home/pi/i2c.py", line 14, in <module>
db=data2()
File "/home/pi/i2c.py", line 7, in data2
IOError: [Errno 5] Input/output error
can anyone help me how to solve it and what this error means.
Return to “Python”
