klintkrossa
python3 CGI broken in apache2
Thu Oct 13, 2016 6:21 pm
Hello
I started new setup of Jessie and apache2.
I'm trying to set up apache2 to use python3 cgi. I keep getting a 404 error. All the googling that I have done has old fixes for this error. It would be great to have a fix for this. Is there a link out there that has the new apache2 fix for python3 CGI?
Klint
P.S. I need some of the apache2 features.
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
Re: python3 CGI broken in apache2
Sat Oct 15, 2016 8:11 am
If you get any error from Apache2 then start by looking at the logs in /var/log/apache2 that should give you a clue where to start investigating your problems.
This is a doctor free zone.
klintkrossa
Sat Oct 15, 2016 5:58 pm
I'll try that.
klintkrossa
Sun Oct 16, 2016 3:52 pm
Now all I get is the script as test on the webpage.
Sun Oct 16, 2016 7:37 pm
klintkrossa
Thu Oct 20, 2016 2:41 pm
Thanks,
I did that and this it is working
/etc/apache2/conf-enabled/server-cgi-bin.conf
<IfModule mod_alias.c>
    <IfModule mod_cgi.c>
        Define ENABLE_USR_LIB_CGI_BIN
    </IfModule>
    <IfModule mod_cgid.c>
    </IfModule>
    <IfDefine ENABLE_USR_LIB_CGI_BIN>
        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
        <Directory "/usr/lib/cgi-bin">
            AllowOverride All
            Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
            Order allow,deny
                        Allow from all
                        AddHandler cgi-script .py
        </Directory>
    </IfDefine>
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
sudo adduser pi www-data
sudo chown pi:www-data -R /var/www
sudo chmod 0755 -R /var/www
sudo chmod g+s -R /var/www
chown -R www-data /var/www
chgrp -R www-data /var/www
chown -R www-data /usr/lib/cgi-bin
chgrp -R www-data /usr/lib/cgi-bin
Require all granted
Then
a2enmod cgi
sudo systemctl restart apache2.service
sudo systemctl status apache2.service
If there is any errors, there is something wrong in the server-cgi-bin file.
Return to “Python”
