Hek
LED Strip Dimming
Mon Oct 10, 2016 7:55 pm
I have a White LED Strip and i wanna dim it with RPi.
So this is my circuit(the wires are on other pins, and i have multimeter connected right now) Image.
Parts:
Power Supply
RPi B2
Dual H Bridge DC Stepper Motor Drive Controller Board Module Arduino L298N HG
LED Strip
Theory is that i should with pwm control output, but only output which i'm getting is like +/-0.0001V
my code is
import wiringpi
import time
wiringpi.wiringPiSetupGpio()
wiringpi.pinMode(18, 2)
wiringpi.pwmWrite(18, 0)
value = 0
increment = 4
increasing = True
count = 0
while count < 100000:
       wiringpi.pwmWrite(18, value)
       if increasing:
               value += increment
               time.sleep(0.002)
       else:
               value -= increment
               time.sleep(0.002)
       if (value >=1024):
               increasing = False
       if (value <= 0):
               increasing = True
       time.sleep(0.002)
       count = count + 1
texy
Re: LED Strip Dimming
Wed Oct 12, 2016 2:11 pm
You diagram shows Ground connected to pin 4 of the pi, not pin 6 ?
Texy
Return to “Python”
