Chris_J
Running a bash command from python with arguments
Sat Sep 24, 2016 10:26 pm
I'm running a Python program that creates a video file and saves it to a location.
After the file has been saved, I'd then like to run a bash command that converts the video from a h264 file to an mp4. At the same time, I'd like to give the mp4 file a name that contains a timestamp but I can't figure out how to send the timestamp to the bash command. Here's what I have so far:
convert_video = "MP4Box -add /home/pi/video.h264 /home/pi/videos/"+timestamp+".mp4"
while True:
    pir.wait_for_motion()
    while pir.motion_detected:
        print('Taking photo')
        ts = '{:%Y%m%d-%H%M%S}'.format(datetime.now())
        logging.info('Taking photo: '+ str(ts)+'.jpg')
        with picamera.PiCamera() as cam:
            cam.resolution=(1024,768)
            cam.annotate_background = picamera.Color('black')
            cam.start_recording('/home/pi/video.h264')
            start = datetime.now()
            while (datetime.now() - start).seconds < 5:
                cam.annotate_text = datetime.now().strftime('%d-%m-%y %H:%M:%S')
                cam.wait_recording(0.2)
            cam.stop_recording()
        time.sleep(0.5)
        timestamp = datetime.now().strftime('%d-%m-%y %H:%M:%S')
        call ([convert_video, timestamp], shell=True)
    print('Motion Ended')
The goal is to make sure all the saved mp4 files have a filename containing the time they were created.
Thanks,
Chris
tom.slick
Re: Running a bash command from python with arguments
Sun Sep 25, 2016 6:44 am
Try posting more code. You left a few holes.
elParaguayo
Sun Sep 25, 2016 6:55 am
Assuming format is
MP4Box -add inputfile outputfile
I would do something like this:
timestamp = datetime.now().strftime('%d-%m-%y_%H-%M-%S')  # I've removed colons and spaces
input_video = "/home/pi/video.h264"
output_video = "/home/pi/videos/{}.mp4".format(timestamp)
call(["MP4Box", "-add", input_video, output_video])
You should be able to adapt your code to fit this in.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
IanH
Sun Sep 25, 2016 7:08 am
You'll need this
from subprocess import call
at the top of the file. If you want to check whether the call has worked, do something like this:
retcode = call(["MP4Box", "-add", input_video, output_video])
if retcode != 0:
    # It went wrong...
    print "Couldn't convert", input_video
For more information, the subprocess module docs are at: https://docs.python.org/2/library/subprocess.html
https://github.com/IanHarvey
elParaguayo
Sun Sep 25, 2016 7:21 am
IanH wrote:
You'll need this
Absolutely. I assumed it was already in the code as the OP's code used the "call" command.
if retcode != 0:
    # It went wrong...
Yes - helpful to include this too. Does rely on MP4Box having differing return codes but hopefully it does!
Chris_J
Sun Sep 25, 2016 8:58 am
Thank you all to your quick replies.
This helped a lot. I didn't quite grasp how to send arguments to bash but this clears it up nicely!
Many thanks,
Chris
Return to “Python”
