davef21370
Thread Problem
Fri Sep 23, 2016 5:01 pm
First time I've needed to use threads but stumbled at the first hurdle. I thought this code...
from threading import Thread
import time
def test():
    for i in range(3):
        print i
        time.sleep(1.0)
a = Thread(test())
b = Thread(test())
a.start()
b.start()
...would produce
0
0
1
1
2
2
But I'm getting
0
1
2
0
1
2
Which means they're running one after another, not simultaneously.
Ideas?
Dave.
Apple say... Monkey do !!
tom.slick
Re: Thread Problem
Fri Sep 23, 2016 6:29 pm
import time
def test():
    for i in range(3):
        print i
        time.sleep(1.0)
a = Thread(target=test)
b = Thread(target=test)
a.start()
b.start()
target is the callable object to be invoked by the run() method. Defaults to None, meaning nothing is called.
davef21370
Re: Thread Problem
Fri Sep 23, 2016 6:46 pm
I get it now, sorted, thanks.
Dave.
Return to “Python”
