forumisto
problems working with json
Thu Sep 15, 2016 10:27 am
Hello
I have a JSON file that if I open it with xed there are characters shown as square with numbers inside.
I can read the file as text but I can not work with it as json object, the method json.loads(txt) fails. The error message is: ValueError: No JSON object could be decoded
How can I use it as json object?
Thank you.
scotty101
Re: problems working with json
Thu Sep 15, 2016 11:12 am
Can you post either
a. A link to your code
b. Your code in between [code][/code] tags
It is going to be very difficult to help you debug the problem without seeing your code.
B.Goode
Thu Sep 15, 2016 11:25 am
The argument to json.loads() should be a string, not a reference to a file.
Maybe you are calling the wrong method to inspect the data?
Examples here: https://docs.python.org/3/library/json.html
forumisto
Thu Sep 15, 2016 11:46 am
txt is a string
I can't paste the content of the string because there is an error when I try submit (SQL ERROR [ mysqli ]; Incorrect string value: '\xF0\x9F\x8E\xAC&q...' for column 'post_text' at row 1 [1366])
The code only is:
import json
data = open('list.w3u').read()
data = json.loads(data)
scotty101
Thu Sep 15, 2016 12:12 pm
Try using this snippet of code to see if you can read in the file
import json
from pprint import pprint
with open('<NAMEOFYOURFILE>') as data_file:
    data = json.load(data_file)
pprint(data)
Failing that, it might be an issue with the encoding of your file. Have a look at this post on Stack Exchange for tips of how to read file with different encoding
http://stackoverflow.com/questions/2835 ... -in-python
For example
with open('data.json', encoding='utf-8') as data_file:
    data = json.loads(data_file.read())
Return to “Python”
