Page 2 of 2
Re: Stopwatch
Posted: Mon Nov 04, 2013 3:37 pm
by Sleep Mode zZ
Wibbes wrote:hi bard
long time since i have being looking into this, i have started working back in windows to give it a bit more power for a 6 lane setup.
one the main problems for the pi is its speed, especially when trying to monitor 2 or more lanes it becomes very hard to time them accurately , think best i got to be reliable was around 0.25 of a second on 2 lanes maybe 0.2 if i trimmed it down a bit on the drawing cycles for the screen.
to be fair even in windows its hard to do real timings without dedicated external hardware to do the timing( arduino or over micro).
You probably could get more speed by changing how you draw and update the screen - if graphics is the bottleneck. Pygame is not very fast at drawing and updating the screen on the Pi. But the whole approach of having the timing (stopping of the timer) depend on the GUI loop seems to me flawed. With that approach you can't expect to get better timing resolution than the GUI's frame rate.
Maybe you could separate the timing loop from the display/control loop into a separate thread or process?
Another idea: While I don't know anything about how the GPIO works - but would it somehow be possible to use interrupts instead of reading the state periodically?
You code seems clean and simple and hope that some more experienced in Python and GPIO would take a look and show how to achieve a better timing resolution.
Re: Stopwatch
Posted: Wed Dec 04, 2013 1:45 pm
by nigel.arnold
Hi
This is something I'm also working towards - when I get some free time that is ;)
I've already built an HO slot table - please see http://www.slickslots.co.uk
In building this table I've drawn heavily from Gregory Braun's site - http://www.hoslotcarracing.com/
However, the current lap time and power control is via a clunky old laptop with a parallel printer port so I was always looking to convert the control element to an integral Raspberry Pi at some point.
Hopefully the links will help those in need of some more info on the basic slot car control electronics at least.
Cheers.
Re: Stopwatch
Posted: Sun Dec 08, 2013 1:57 pm
by bard
Hi all,
After double-checking, I really think a Pi unit can easily track a few events per second (start the clock, record track times for a few lanes, ....).
I will investigate more wth Python and C# to find pieces of code or a friend that could do it for me (I haven't coded in decades and have to see if I can do it again in langages I would have to learn...).
Let's keep investigating and keep in touch.
@joan and @Sleep Mode zZ: totally agree with you guys
@nigel.arnold: the different electronic setups for lap timing (photocells, dead strip, webcams, Reed or Hall effect sensors,....) amount to the same for the prog: recording an event (line x, time) after seeing a pulse on a "port"
My approach would be as Sleep Mode zZ suggested:
- a process/thread for the display
- another process for the clock
When a car passes the line (thus generating an interrupt/pulse), recording of the time and the lane is sent to the "database" and the display process.
In this case, even if the display in a little slow, we are closer to getting accurate timing on all events stated before (timing sectors, jump starts,...)
I'm sure as soon as this project gets momentum, more coding experts will contribute.
Cheers.
Bard
Re: Stopwatch
Posted: Thu Oct 30, 2014 1:31 am
by benson1658
Hi
I'm pretty New to coding and was given the task of making a time attack system for drift trike racing. I'm thinking of getting some pir motion sensors and rigging them up as start and finish lines on the course. This project seems to be suited although I don't require laptimes. Just a start and stop. How could I modify the code for 2 sets of gpio pins one to start. The other to stop the stopwatch? Any help would be fantastic
Re: Stopwatch
Posted: Thu Dec 31, 2015 11:22 am
by Marre
Hi all,
I put a litte stop watch, race timer together using my Pi 2, IR-LEDs and Python. It's not pretty and I'm going to add some Pygame graphics later on (any help here highly appreciated), but it's working :)
It handles 2 lanes, best lap time for each track (please note you need to create the empty files using the files names in the code for this).
The electrical circuits are presented in attached pictures along with component lists.
I'm sure it can be improved and any suggestions are welcome.
Anyways you can see a presentation here with further instructions in the end: https://youtu.be/TH52RCSOLeo
''' Race Timer
This timer uses
Best time is loaded into
False start and best laptime
Clean exit
Stop if cheat
Average speeds
Buzzer
from decimal import Decimal
import RPi.GPIO as GPIO
import time
import random
import pickle
GPIO.setmode(GPIO.BCM)
redlight = 17
greenlight = 27
buzzer = 22
#Pin for start lights & buzzer
GPIO.setup(redlight, GPIO.OUT)
GPIO.setup(greenlight, GPIO.OUT)
GPIO.setup(buzzer, GPIO.OUT)
#Pin for Racer 1
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
#Pin for Racer 2
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
#Declare variables
L1_time = 0
L2_time = 0
best_Ferrari1 = pickle.load( open( "Ferrari.p", "rb" ) ) #Lane 1 save file
best_RedBull2 = pickle.load( open( "RedBull.p", "rb" ) ) #Lane 2 save file
L1_best_time = time.time()
L2_best_time = time.time()
L1_lap = -1    #1st pass of finish line starts the 1st lap
L2_lap = -1    #1st pass of finish line starts the 1st lap
Total_time = 0
Laps = 10       #Set No. of laps
falsestart = 1 #Default false start, set to false same time as green light is lit
cheat = False
course_length = 8.9 #This is the lenght of the track
avg_speed = 0
top_speed_1 = 0
top_speed_2 = 0
try:
    def my_racer1(channel):
        global L1_best_time
        global start_time
        global L1_lap
        global L1_time
        global cheat
        L1_lap += 1
        if (L1_lap == 0):
            if falsestart == 1:
                print ("Team Ferrari jumped the start!")
                cheat = True
            else:
                pass
        elif (L1_lap == 1):
            elap = time.time() - start_time
            L1_best_time = elap
            L1_time = time.time()
            print ("Racer 1 Lap: " + str(L1_lap) + " - " + time_converter(elap))
        else:
            elap = time.time() - L1_time
            if (elap < L1_best_time):
                L1_best_time = elap #Keeping the best lap time for this race
    def my_racer2(channel):
        global L2_best_time
        global start_time
        global L2_lap
        global L2_time
        global cheat
        L2_lap += 1
        if (L2_lap == 0):
            if falsestart == 1:
                print ("Team RedBull jumped the start!")
                cheat = True
            else:
                pass
        elif (L2_lap == 1):
            L2_best_time = elap
            L2_time = time.time()
            print ("Racer 2 Lap: " + str(L2_lap) + " - " + time_converter(elap))
        else:
            elap = time.time() - L2_time
            if (elap < L2_best_time):
                L2_best_time = elap #Bara hlla koll på bästa tiden this race
    def time_converter(conv_time):
        minutes = int(conv_time/60)
        seconds = int(conv_time - minutes*60.0)
        hseconds = int((conv_time - minutes*60.0 - seconds)*100)
        return str('%02d:%02d:%02d' % (minutes, seconds, hseconds))
    #Start lights reset
    GPIO.output(redlight, 0)
    GPIO.output(greenlight, 0)
    GPIO.output(buzzer, 0)
    print ("Ferrari best laptime is: " + time_converter(best_Ferrari1))
    print ("RedBull best laptime is: " + time_converter(best_RedBull2))
    print ("Race is set to: " + str(Laps) + " laps.")
    input ("Press Enter when ready to race!\n>")
    print ("Press CTRL+C to end race.")
    #Racer 1 event
    time.sleep(0.1)
    GPIO.add_event_detect(23, GPIO.RISING, callback=my_racer1, bouncetime=2500)
    #Racer 2 event
    time.sleep(0.1)
    GPIO.add_event_detect(24, GPIO.RISING, callback=my_racer2, bouncetime=2500)
    #Start light sequence
    time.sleep(1)
    for x in range(0, 3):
        GPIO.output(redlight, 1)
        GPIO.output(buzzer, 1)
        time.sleep(0.3)
        time.sleep(1)
    time.sleep(random.uniform(1, 3))
    falsestart = 0
    GPIO.output(greenlight, 1)
    #Timing starts and ensures no false start
    start_time = time.time()
    time.sleep(1)
    while ((L1_lap < Laps) and (L2_lap < Laps) and cheat == False):
        continue
    print("\n") #Just to printout nicely
    if cheat == True:
        print("We have a cheater, race stops!")
        for x in range(0, 5):
            time.sleep(0.3)
            time.sleep(0.3)
    else:
        Total_time = time.time() - start_time
        if L1_lap > L2_lap:
            print ("Team Ferrari is the winner!\n")
        else:
            print ("Team RedBull is the winner!\n")
        avg_speed = Decimal((course_length * Laps) / float(Total_time) * 3.6)
        top_speed_1 = Decimal(course_length / float(L1_best_time) * 3.6)
        top_speed_2 = Decimal(course_length / float(L2_best_time) * 3.6)
        if (L1_lap < 1):
            print ("Team Ferrari did not complete 1 lap.\n")
        else:
            print ("Team Ferrari's best lap: " + time_converter(L1_best_time))
            print ("Team Ferrari's top avg. speed: " + str(round(top_speed_1, 2)) + " km/h\n")
        if (L2_lap < 1):
            print ("Team RedBull did not complete 1 lap.\n")
        else:
            print ("Team RedBull's best lap: " + time_converter(L2_best_time))
            print ("Team RedBull's top avg. speed: " + str(round(top_speed_2, 2)) + " km/h\n")
        print ("\nTotal time of race for winner: " + time_converter(Total_time))
        print ("Winner's avg. speed: " + str(round(avg_speed, 2)) + " km/h\n")
        if (L1_best_time < best_Ferrari1): #Check and save Ferrari lap record on lane 1
            print("We have a new Ferrari lap record on lane 1! " + time_converter(L1_best_time))
            pickle.dump(L1_best_time, open("Ferrari.p", "wb" ))
        else:
            print("No new lap record for Ferrari this race.")
        if (L2_best_time < best_RedBull2): #Check and save RedBull lap record on lane 2
            print("We have a new RedBull lap record on lane 2! " + time_converter(L2_best_time))
            pickle.dump(L2_best_time, open("RedBull.p", "wb" ))
        else:
            print("No new lap record for RedBull this race.")
            time.sleep(0.3)
            time.sleep(1)
except KeyboardInterrupt:
    print("User controlled exit")
except:
    print ("Another exception")
finally:
    print("Cleaning up PINS")
    GPIO.cleanup()  #cleanup regardless of reason for exit.
Re: Stopwatch
Posted: Mon Jan 18, 2016 9:29 pm
by Marre
As promised, I've now managed to learn some basic Pygame and updated the Race timer accordingly.
You can also run another race without exiting the program. Fonts, images and sounds can be downloaded from enywhere.
A couple of lessons learned:
1. GPIO.cleanup() did not remove GPIO.add_event_detect, which was causing trouble with multiple firing of events at the same time during reruns of the timer.
2. Running python from IDLE3 over vnc client on my PC rendered no graphics. It was solved using gksu to start IDLE3. Another way was to start it using /usr/bin/python3.4 without gksu.
Here is the code for anyone interested. My kids slotcar track has become so much more fun with this :)
Good luck with your projects! I'm happy to help if anyone has questions related to this.
EDIT: I amended the code slightly to add sound in the end of race and not to reflect -1 lap in the beginning.
EDIT2: I've uploaded a video here: https://youtu.be/dPD9qsKATBE
''' Race Timer using Pygame for graphics
Best lap times  is saved in files
False starts are handled as aborted races
Start and end signal with buzzer
Enables rerun of race
3.1 1st lap not -1
import time
import random
import pickle
import pygame
# Declare variables
L1_time = 0
L2_time = 0
elap_f = 0
elap_r = 0
path = "/home/pi/Programming/Pygame/RaceTimer" # Set full path
best_Ferrari = pickle.load(open(path + "/SG/Ferrari.p", "rb")) # Lane 1 save file
best_RedBull = pickle.load(open(path + "/SG/RedBull.p", "rb")) # Lane 2 save file
L1_best_time = 10
L2_best_time = 10
L1_lap = -1    # 1st pass of finish line starts the 1st lap
L2_lap = -1    # 1st pass of finish line starts the 1st lap
Total_time = 0
Laps = 5       # Set No. of laps
Laps_Ferrari = 0 #Used to print laps
Laps_RedBull = 0 #Used to print laps
falsestart = True # Default false start, set to false same time as green light is lit
cheat = False
Ferrari_cheat = False
RedBull_cheat = False
course_length = 8.9 # This is the lenght of the track
avg_speed = 0
top_speed_1 = 0
top_speed_2 = 0
# Startlight & buzzers GPIO PIN numbers
redlight = 17
greenlight = 27
buzzer = 22
# Define some colors
WHITE = (255, 255, 255)
BLACK = (0, 0, 0)
RED = (255,40,0)
DARKBLUE = (0,0,128)
# Define separator line thickness (lh) and relative position separator (th)
lh = 15
th = 70
# Call this function so the Pygame library can initialize itself
pygame.init()
pygame.font.init()
# Create an 1600x900 sized screen, good to to use fullscreen when testing code.
screen = pygame.display.set_mode((1600, 900), pygame.FULLSCREEN)
#screen = pygame.display.set_mode((1600, 900))
# This sets the name of the window
pygame.display.set_caption("Race Timer")
# Add refresh rate ability
clock = pygame.time.Clock()
# Before the loop, load the sounds:
pygame.mixer.init()
pygame.mixer.music.set_volume(1.0)
click_sound = pygame.mixer.Sound(path + "/F1-new3.ogg")
# Set positions of graphics
dI = pygame.display.Info()
background_position_ferrari = [lh, lh]
background_position_redbull = [lh, dI.current_h/2 + lh*2]
# Create background and copy images to screen:
rectFerrari = pygame.Rect(0,0,dI.current_w,dI.current_h/2)
rectLine = pygame.Rect(0,dI.current_h/2,dI.current_w,lh)
rectRedbull = pygame.Rect(0,dI.current_h/2 + lh,dI.current_w,dI.current_h/2 - lh)
# Font for text in GUI
myFont = pygame.font.Font(path + "/Fonts/DS-DIGI.TTF", 75)
myFont2 = pygame.font.Font(path + "/Fonts/DS-DIGI.TTF", 45)
# Create labels variables
BT = myFont.render("Best Lap", 1, WHITE)
LT = myFont.render("Last Lap ", 1, WHITE)
RT = myFont.render("Record", 1, WHITE)
Lap_No = myFont.render("Lap No:", 1, WHITE)
# Load and set up graphics.
ferrari_image = pygame.image.load(path + "/Pics/ferrari.jpg").convert()
redbull_image = pygame.image.load(path + "/Pics/redbull.jpg").convert()
ferrari_image = pygame.transform.scale(ferrari_image, (341, 148))
redbull_image = pygame.transform.scale(redbull_image, (341, 148))
def wait():
    while True:
        for event in pygame.event.get():
            if event.type == pygame.KEYDOWN and event.key == pygame.K_RETURN:
                return
def raceAgain():
    global reRun
    global cheat
    global Ferrari_cheat
    global RedBull_cheat
    while True:
            if event.type == pygame.KEYDOWN and event.key == pygame.K_y:
                return
            if event.type == pygame.KEYDOWN and event.key == pygame.K_n:
                reRun = False
                return
    global L1_best_time
    global start_time
    global L1_lap
    global L1_time
    global Laps_Ferrari
    global cheat
    global elap_f
    L1_lap += 1
    if (L1_lap == 0):
        if falsestart:
            Ferrari_cheat = True
            cheat = True
        else:
            pass
    elif (L1_lap == 1):
        Laps_Ferrari = L1_lap
        elap_f = time.time() - start_time
        if (elap_f < L1_best_time):
            L1_best_time = elap_f # Keeping the best lap time for this race
    else:
        elap_f = time.time() - L1_time
    global L2_best_time
    global start_time
    global L2_lap
    global L2_time
    global Laps_RedBull
    global cheat
    global elap_r
    L2_lap += 1
    if (L2_lap == 0):
        if falsestart:
            RedBull_cheat = True
            cheat = True
        else:
            pass
    elif (L2_lap == 1):
        Laps_RedBull = L2_lap
        elap_r = time.time() - start_time
        if (elap_r < L2_best_time):
            L2_best_time = elap_r # Keeping the best lap time for this race
    else:
        elap_r = time.time() - L2_time
def drawResults():
    #Update times & Laps
    L1_best_time_text = myFont.render(time_converter(L1_best_time), 1, DARKBLUE)
    L1_time_text = myFont.render(time_converter(elap_f), 1, DARKBLUE)
    L1_lap_text = myFont.render(str(Laps_Ferrari), 1, DARKBLUE)
    L2_best_time_text = myFont.render(time_converter(L2_best_time), 1, RED)
    L2_time_text = myFont.render(time_converter(elap_r), 1, RED)
    L2_lap_text = myFont.render(str(Laps_RedBull), 1, RED)
    # Draw background and copy images to screen:
    screen.fill(RED, rectFerrari)
    screen.fill(BLACK, rectLine)
    screen.fill(DARKBLUE, rectRedbull)
    screen.blit(ferrari_image, background_position_ferrari)
    screen.blit(redbull_image, background_position_redbull)
    # Print Ferrari labels + time
    screen.blit(LT,                 (dI.current_w/3 + lh    , lh))
    screen.blit(BT,                 (2*dI.current_w/3 + lh  , lh))
    screen.blit(RT,                 (lh                     , dI.current_h/5 + lh))
    screen.blit(Lap_No,             (dI.current_w/3 + lh    , dI.current_h/5 + lh))
    screen.blit(L1_time_text,       (dI.current_w/3 + lh    , lh + th))
    screen.blit(L1_best_time_text,  (2*dI.current_w/3 + lh  , lh + th))
    screen.blit(RT_Ferrari,         (lh                     , dI.current_h/5 + lh + th))
    screen.blit(L1_lap_text,        (dI.current_w/2 - lh    , dI.current_h/5 + lh))
    # Print RedBull labels + time
    screen.blit(LT,                 (dI.current_w/3 + lh    , dI.current_h/2 + lh))
    screen.blit(BT,                 (2*dI.current_w/3 + lh  , dI.current_h/2 + lh))
    screen.blit(RT,                 (lh                     , dI.current_h/2 + dI.current_h/4))
    screen.blit(Lap_No,             (dI.current_w/3 + lh    , dI.current_h/2 + dI.current_h/4))
    screen.blit(L2_time_text,       (dI.current_w/3 + lh    , dI.current_h/2 + lh + th))
    screen.blit(L2_best_time_text,  (2*dI.current_w/3 + lh  , dI.current_h/2 + lh + th))
    screen.blit(RT_RedBull,         (lh                     , dI.current_h/2 + dI.current_h/4 + th))
    screen.blit(L2_lap_text,        (dI.current_w/2 - lh    , dI.current_h/2 + dI.current_h/4))
    pygame.display.flip()
reRun = True
# Check to race again
while reRun:
    # Initialize GPIO PINS
    # GPIO PIN for Lane 1 sensor Team Ferrari
    # GPIO PIN for Lane 2 sensor Team RedBull
    #Racer 1 event
    time.sleep(0.1)
    #Racer 2 event
    time.sleep(0.1)
    # Reset variables for reRun
    L1_time = 0
    L2_time = 0
    elap_f = 0
    elap_r = 0
    L1_best_time = 10
    L2_best_time = 10
    Total_time = 0
    cheat = False
    #course_length = 8.9 # This is the lenght of the track
    avg_speed = 0
    top_speed_1 = 0
    top_speed_2 = 0
    #Define Record times & start message
    RT_Ferrari = myFont.render(time_converter(best_Ferrari), 1, DARKBLUE)
    RT_RedBull = myFont.render(time_converter(best_RedBull), 1, RED)
    Intro_text = myFont.render("Press Enter when ready to race!", 1, DARKBLUE)
    Exit_text = myFont.render("Press q to quit race.", 1, WHITE)
    Laps_text = myFont.render("Race is set to: " + str(Laps) + " laps.", 1, DARKBLUE)
    # Print Ferrari labels + record time
    # Print RedBull labels + record time
    # Print start message
    screen.blit(Intro_text, (dI.current_w/4         , lh + 2*th))
    screen.blit(Exit_text, (dI.current_w/3          , lh + 3*th))
    screen.blit(Laps_text, (dI.current_w/3 - lh     , lh + 4*th))
    # Update screen
    # Play intro sound
    click_sound.play()
    pygame.mixer.fadeout(6000)
    # Waits for user to press Enter
    wait()
    pygame.mixer.quit()
    try:
        #Start lights reset
        time.sleep(1)
            time.sleep(0.3)
            time.sleep(1)
        falsestart = False
        time.sleep(1)
        done = False
        while ((L1_lap < Laps) and (L2_lap < Laps) and not cheat and not done):
                if event.type == pygame.KEYDOWN and event.key == pygame.K_q:
                    done = True
            drawResults()
            clock.tick(60)
        #Present final results
        drawResults()
        if cheat:
            if Ferrari_cheat:
                f_cheat_text = myFont.render("Team Ferrari jumped the start!", 1, DARKBLUE)
                screen.blit(f_cheat_text, (dI.current_w/4 , 5*th))
            if RedBull_cheat:
                r_cheat_text = myFont.render("Team RedBull jumped the start!", 1, RED)
                screen.blit(r_cheat_text, (dI.current_w/4 , dI.current_h/2 + 5*th))
            pickle.dump(best_Ferrari, open(path + "/SG/Ferrari.p", "wb" ))
            pickle.dump(best_RedBull, open(path + "/SG/RedBull.p", "wb" ))
            # False start signal
                time.sleep(0.3)
                time.sleep(0.3)
            pygame.mixer.init()
            click_sound.play()
        else:
            if L1_lap > L2_lap:
                f_winner_text = myFont2.render("Team Ferrari is the winner with time: " + time_converter(Total_time), 1, WHITE)
                screen.blit(f_winner_text, (dI.current_w/4 , 4*th))
            if L1_lap < L2_lap:
                r_winner_text = myFont2.render("Team Redbull is the winner with time: " + time_converter(Total_time), 1, WHITE)
                screen.blit(r_winner_text, (dI.current_w/4 , dI.current_h/2 + 4.4*th))
            # Calculate race stats
            if (L1_lap < 1):
                f_stats_text = myFont2.render("Team Ferrari did not complete 1 lap", 1, WHITE)
                screen.blit(f_stats_text, (dI.current_w/4 , 4*th))
            else:
                f_stats_text = myFont2.render("Team Ferrari's top avg. speed: " + str(round(top_speed_1, 2)) + " km/h", 1, WHITE)
                screen.blit(f_stats_text, (dI.current_w/4 , 4.7*th))
            if (L2_lap < 1):
                r_stats_text = myFont2.render("Team RedBull did not complete 1 lap", 1, WHITE)
                screen.blit(r_stats_text, (dI.current_w/4 , dI.current_h/2 + 4.4*th))
            else:
                r_stats_text = myFont2.render("Team RedBull's top avg. speed: " + str(round(top_speed_2, 2)) + " km/h", 1, WHITE)
                screen.blit(r_stats_text, (dI.current_w/4 , dI.current_h/2 + 5.1*th))
            if (L1_best_time < best_Ferrari): #Check and save Ferrari lap record on lane 1
                f_rec_text = myFont2.render("We have a new Ferrari lap record on lane 1! Press Enter.", 1, WHITE)
                screen.blit(f_rec_text, (dI.current_w/4 , 5.4*th))
                pickle.dump(L1_best_time, open(path + "/SG/Ferrari.p", "wb" ))
            else:
                f_rec_text = myFont2.render("No new lap record for Ferrari this race, press Enter.", 1, WHITE)
            if (L2_best_time < best_RedBull): #Check and save RedBull lap record on lane 2
                r_rec_text = myFont2.render("We have a new RedBull lap record on lane 2! Press Enter", 1, WHITE)
                screen.blit(r_rec_text, (dI.current_w/4 , dI.current_h/2 + 5.8*th))
                pickle.dump(L2_best_time, open(path + "/SG/RedBull.p", "wb" ))
            else:
                r_rec_text = myFont2.render("No new lap record for Ferrari this race, press Enter.", 1, WHITE)
            pygame.mixer.init()
            click_sound.play()
            # End of race signal
                time.sleep(0.3)
                time.sleep(0.5)
        # Necessary as GPIO.cleanup() won't remove detect events.
        GPIO.remove_event_detect(23)
        GPIO.remove_event_detect(24)
        pygame.quit()
    except:
        pygame.quit()
    finally:
    # Waits for user to press enter
    wait()
    #Text to race again
    race_again_text = myFont.render("Race again (y/n)?", 1, DARKBLUE)
    drawResults()
    screen.blit(race_again_text, (dI.current_w/4 , 5*th))
    # Update screen
    #Check to race again
    raceAgain()
# Under while loop
pygame.quit()
Re: Stopwatch
Posted: Thu Jan 21, 2016 11:05 am
by paulv
There is a (reported) bug in the GPIO.add_event_detect() code.
Detecting Falling edges work, Rising edges do not, they produce triggers on both edges, as if you used Both.
Re: Stopwatch
Posted: Thu Jan 21, 2016 9:39 pm
by Marre
Good thing it's noted. I forgot to mention I solved it using:
GPIO.remove_event_detect(pin/channel), which clears it each rerun of the program, so no problem in my program with that.
So I didn't really have the problem with triggering on up+down, rather the add events kept stacking up, so run 1 was fine, rerun 1it detected 2 laps at a time, 2nd 3 laps etc, despite gpio.cleanup() was run before each rerun.
Keep in mind the bounce time of the events, I've set them to 2500ms, so if you've got faster lap times than that, you need to change it to cater for that or you'll be having problems.
/M
Re: Stopwatch
Posted: Sat Jan 23, 2016 6:10 pm
by Marre
Due to the fact that I'm running the screen on my PC with TightVNC client, I learnt some other things today:
- There is a lot of "hissing" going on over the 3.5mm audio output. To handle this during the race, I've added stopped the sound (pygame.mixer.stop()) and reinitialized it for each run. The HDMI output does not seem to suffer from this, so use it if you can.
- My suggestion is not to run TightVNC over wifi, it's lagging and gets clogged up, whilst LAN-cable works just fine.
Re: Stopwatch
Posted: Sun Mar 12, 2017 7:43 pm
by with ice cream
Marre wrote:please note you need to create the empty files using the files names in the code for this
I came across your Stopwatch code and plan to adapt it to a solution with a 2.8" GPIO touch screen. It seems that simply touching the necessary files isn't enough. Would it be possible to provide an example?
Thanks!
