cscuilla
Read MySQL table to python dictionary
Tue Sep 06, 2016 5:27 pm
I'm building a timeclock using rpi and an rfid reader. With some help from other users, I was able to store users ID and username into a CSV file python dictionary, so that when an rfid tag is scanned, it looks for a match within the python dictionary.
I have then made a Mysql database where I am storing the punches.
So now, I am thinking it would be better to pull the initial scan from the mysql database as well and get rid of the csv file. I do not understand how the dictionary code is written, so am unable to accomplish this. I am able to connect to the DB w/o issue. Here is my current code using the dictionary. Where it currently says #Do Something, is where I am currently connecting to my DB, and recording the punches. So I will need to connect to the DB at first launch and read the values from my table into the dictionary instead of the csv file values..
import MFRC522
import signal
import datetime
import time
import os
import sys
import RPi.GPIO as GPIO
import csv
import MySQLdb
from time import sleep
from Adafruit_CharLCD import Adafruit_CharLCD
# VARIABLES
uid_dict = dict()
uid_file = "/mnt/lock_logs/timeclock.csv"
fieldnames = ['UUID', 'USERS']
# UID DICTIONARY
with open(uid_file, "r") as f:
    reader = csv.DictReader(f, fieldnames=fieldnames, delimiter=",")
    for row in reader:
        uid_dict[row['USERS'].strip()] = [int(i) for i in row['UUID'].split()]
while continue_reading:
  (status,TagType) = MIFAREReader.MFRC522_Request(MIFAREReader.PICC_REQIDL)
  (status,backData) = MIFAREReader.MFRC522_Anticoll()
  for key, value in uid_dict.iteritems():
       if backData == value:
            #Do Something
Re: Read MySQL table to python dictionary
Wed Sep 07, 2016 8:08 am
The way to get a simple SQL statement to run is
import MySQLdb as db
user="mysql_unprivileged_user_with_access_to_my_database"
passwd="MySQL_users_Passwd"
database="my_database"
dbcon = db.connect('localhost', user, passwd, database)
my_sql = "INSERT INTO my_table (column_1, column_2) VALUES("col1 val", "col2 val");"
dbcur = dbcon.cursor()
dbcur.execute(my_sql)
dbcon.commit()
sorry that SQL is an ugly example. There's better examples at http://mysql-python.sourceforge.net/MySQLdb.html
cscuilla
Wed Sep 07, 2016 3:06 pm
Thanks. I can already connect and run queries without issue w/in python. The trouble is with the python dictionary. I'm trying to store all the values from the query w/in a python dictionary.
Wed Sep 07, 2016 7:29 pm
This reads a database and gives you a dict for each row that's returned in the resultset
#!/usr/bin/python
import locale
import MySQLdb
import MySQLdb.cursors
locale.setlocale(locale.LC_ALL, 'en_GB.UTF-8')
db = MySQLdb.connect(host="localhost",
                     user="tester",
                      passwd="tester_password",
                      db="my_database", cursorclass=MySQLdb.cursors.DictCursor)
cur = db.cursor()
cur.execute("SELECT Secret, URL from my_table where Channel = 'maker';")
for row in cur.fetchall() :
    print row['Secret']
    print row['URL']
the cursorclass is the thing that does the magic.
cscuilla
Wed Sep 07, 2016 7:34 pm
Ok. Thank you. This looks Great!!! Won't have time to test until tomorrow. Thanks so much!!
cscuilla
Mon Sep 12, 2016 5:28 pm
Ok, so I had some time to get back to this. I am still having trouble. I will try to explain better..
I have a table called "uid" which has two fields, rfid and empid:
EXAMPLE RECORD 1
rfid = 88 999 33 555
empid = 1
EXAMPLE RECORD 2
rfid = 64 344 77 222
empid = 2
I would like to run a query which stores all of these values in a python dictionary, and allows me to set the rfid number as a variable (MyRFID) to be called later in the script:
db = MySQLdb.connect("MyIp", "MyUser", "MyPass", "MyDB", cursorclass=MySQLdb.cursors.DictCursor)
curs=db.cursor()
curs.execute("""SELECT number, empid FROM rfid """)
So that later in the code I can check to see if I get a match from an existing variable:
if MyVariable == MyRFID:
    #Do Something
Thanks so much for your time!
Mon Sep 12, 2016 7:58 pm
If you create a table with
create table uid (rfid char(13), empid integer);
insert into uid (rfid, empid) values('88 999 33 555', 1);
insert into uid (rfid, empid) values('64 344 77 222', 2);
then your python program has to match the DDL used to create your table
#!/usr/bin/python
import locale
import MySQLdb
                     user="tester",
                      passwd="myverysecretMySQLpassword",
                      db="tester", cursorclass=MySQLdb.cursors.DictCursor)
cur = db.cursor()
cur.execute("SELECT rfid, empid FROM uid;")
    print row['rfid']
    print row['empid']
You can then use
if row['empid'] == 1:
   # do stuff when it's employee #1
and
if row['rfid'] == "64 344 77 222":
   # do stuff when you've got rfid "64 344 77 222"
sonorobby
Mon Nov 28, 2016 8:51 pm
Hello cscuilla, in your first post you wrote, that you realized a cose to import your rfid tag into an excel. can u provide the code? I am new in programming with python and want to test something a littel bit.
I am also interessted in the code to import into mysql...
would be great
Return to “Python”
