JF002
Play sound (mp3, streams,...) using Python
Tue Aug 28, 2012 8:42 pm
Hi!
For my project, I want to be able to play music files (MP3 stored locally or on the network, web streams,...) using Python3 (and PySide/QT4).
I found several possibilities :
* Phonon (from QT)
* Pygame
* gstreamer
* OmxPlayer
And I was wondering which was the best solution to play sound file and have some feedback on the playing (position in the file, total duration,...). For now, my goal is to implement a music player.
From what I understood, OmxPlayer was developped specifically for the Rpi and uses hardware for decoding. It could be the best for performances.
But... Does it have some kind of API I could use from Python?
I tried Phonon with no success for now...
Do you have some advices for me?
Thanks!
My web site : https://codingfield.com
KenT
Re: Play sound (mp3, streams,...) using Python
Tue Aug 28, 2012 8:50 pm
Try this. Its Python 2.7 and Tkinter interface to omxplayer
https://github.com/KenT2/tboplayer
If you want a Python interface to omxplayer try https://github.com/jbaiter/pyomxplayer or look at my other github repo
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
JF002
Tue Aug 28, 2012 9:01 pm
Thanks for these links!
The Python interface to OmxPlayer you are using uses pexpect, right? It means that it is interacting with omxplayer using stdin/stdout?
Do you know if a library exists, that would allow me to call some functions (in C) or to instanciate an object (python or c++)?
KenT
Wed Aug 29, 2012 7:37 am
yes it uses stdin/out. I'm not sure what you are looking for in the way of a library, probably best to search around the forum, there have been several threads on interfacing omxplayer.
JF002
Thu Aug 30, 2012 7:21 pm
I'm searching for a library I can link my code to in order to use Omxplayer in my sofware. In Windows world, I would call that a DLL ;)
KenT
Sun Sep 02, 2012 3:21 pm
The omxplayer code is here https://github.com/huceke/omxplayer. I'm not an expert on these matters but a library is not required, just call it as a linux command from within your program, but you will need the pipes to pass it commands while it is running at to get its output.
ghans
Sun Sep 02, 2012 3:44 pm
Omxplayer uses (you may have guessed) the OpenMAX API.
I think there should be Wrappers available for any language , including python.
ghans
JF002
Sun Sep 02, 2012 4:15 pm
ghans wrote:Omxplayer uses (you may have guessed) the OpenMAX API.
ghans
No, I didn't guess that... In fact, I know nothing about OpenMAX, but I'll have a look!
In my opinion, communicating with another thread using stdin/stdout is not the best solution. I would rather like using directly the code from OmxPlayer in my code (or linking against omxplayer). It seems to be a cleaner solution to me.
But OpenMAX could be better... I'll try to get some information!
ghans
Sun Sep 02, 2012 5:53 pm
OpenMAX is a bit hard to work on , i heard.
Perhaps you should look into how ALSA works.
Or you could use aplay or mpg123 (yeah , not a clean solution) .
https://github.com/peterderivaz/pyopenmax can't be the only one .. too lazy to google
more..
ghans
MadCow42
Mon Sep 03, 2012 1:55 pm
ghans wrote:Perhaps you should look into how ALSA works.
PyAlsaAudio works fairly well, and is light with few dependencies (but you have to install libaudio2-dev via apt-get)
http://pyalsaaudio.sourceforge.net/
If you have troubles I can send you a code sample of using it, but it's straight forward.
JF002
Mon Sep 03, 2012 7:58 pm
I'll have a look to PyAlsaPlay too, thanks for the link!
But for now, i'm trying to build a c++ extension for Python that directly uses omxplayer source code. After a lot (a lot, a lot, a lot) of build errors, I finally heard Airbourne (from a MP3 file) from my Pi ! Victory!
I had to build Ffmpeg, omxplayer, then, learn some Python basics, and learn how to build a Python extension... It's quite interesting :)
I'll keep you up to date when I'll something new !
Nuker
Tue Sep 04, 2012 10:19 am
I've been looking for solution for network streaming, i have 20 tv's/projector in this building.
On tv's there is converter from svideo to analog cable. On projectors we have pc's connected to them.
With pc's there is two solutions - either syncronize the whole playlists (which is ~100gb, constanlty changing) so this method for RPi isn't going to work.
So solution is to play network stream, which i'm desperately waiting for.
Unless you have some suggestions as how i can play videos from network server through RPi
Return to “Python”
