mechrohit90
How to Create a user interface in raspberry pi
Wed Aug 24, 2016 8:26 am
I am using raspberry pi and python 2.7.3. I want to create a custom User Interface so that after switch on the raspberry pi user will see the custom screen and they can easily configure the other things..
dddomodossola
Re: How to Create a user interface in raspberry pi
Wed Aug 24, 2016 8:46 am
Nowadays there are two major kind of user interfaces you can adopt, standard guis or webinterfaces. If you use a standard gui you can benefit of speed. With webinterfaces you can access to your interface remotely.
If you are a novice, consider to use tkinter. Otherwise take a look at this https://github.com/dddomodossola/remi.
Return to “Python”
