carlsopa
using a button long press vs short press
Mon Jun 20, 2016 12:41 am
I am working on an alarm clock project. One aspect of it, is when I press it a button, it will either turn on/off the alarm, or go into a set time mode. My current code, currently works but will also trigger the else statement. I assume this is because after the sleep(3) it still registers a press.
I am looking for any suggestions, or ideas that would make my code better. What I would like to do is a long press enters a set mode, while a single press would set the alarm.
if (GPIO.input(Alarm) == False):
  sleep(3)
    AlarmSet = True
    print('set alarm')
    continue
  else:
    Alrm1.setAlarm()
    print('Alarm')
Cancelor
Re: using a button long press vs short press
Mon Jun 20, 2016 8:09 am
One way would be to measure the time that the button is pressed for and then afterwards have some code that decides what to do. :)
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
PiGraham
Mon Jun 20, 2016 8:33 am
It looks like Button in GPIOZero allows an event callback on a hold:
http://bennuttall.com/whats-new-gpio-zero-v1-2/
from gpiozero import Button
def hello():
    print("Hello")
button = Button(2, hold_time=2)
button.when_held = hello
ben_nuttall
Fri Jul 01, 2016 7:51 pm
That's right. See http://gpiozero.readthedocs.io/en/lates ... ero.Button
The above example is as simple as it gets!
Former RPF staff. Author of gpiozero and creator of piwheels.
Redryno
Sat Jul 02, 2016 4:01 am
You could time how long it is between rising edge and falling edge.
Return to “Python”
