cscuilla
Having trouble reading GPIO.IN state
Thu Jun 09, 2016 3:40 pm
I'm using a MFRC522 rfid card reader. I'd like different actions to happen, depending on if a button is pressed or not when the card is scanned. I cannot seem to read the state of the input button correctly, it always stays at 0.
import MFRC522
import signal
import datetime
import time
import os
import sys
import RPi.GPIO as GPIO
import csv
continue_reading = True
MIFAREReader = MFRC522.MFRC522()
#VARIABLES
BTN1 = 18
# COMMANDS
GPIO.setmode(GPIO.BOARD)
GPIO.setup(BTN1, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
os.system("sudo mount -a")
def end_read(signal, frame):
  global continue_reading
  continue_reading = False
  print "Ctrl+C captured, ending read."
  MIFAREReader.GPIO_CLEEN()
signal.signal(signal.SIGINT, end_read)
I believe the issue is within this section of code..
while continue_reading:
    BTN_STATE = GPIO.input(BTN1) # I think this should be moved maybe?
    (status,TagType) = MIFAREReader.MFRC522_Request(MIFAREReader.PICC_REQIDL)
    if status == MIFAREReader.MI_OK:
        print "Card detected"
    (status,backData) = MIFAREReader.MFRC522_Anticoll()
        print "Card read UID: "+str(backData[0])+","+str(backData[1])+","+str(backData[2])+","+str(backData[3])+","+str($
        print BTN_STATE # This always prints 0, even when the button is pressed
Burngate
Re: Having trouble reading GPIO.IN state
Fri Jun 10, 2016 4:30 pm
Would it be worth while concentrating on just the button hardware/software and getting that to work before adding in the rfid hardware/software?
Hardware-wise, I would like to see a circuit diagram, showing how you've connected the button.
Regarding software, the only bits in that code to do with the button that I could see appear to be
BTN1 = 18
cscuilla
Tue Jun 14, 2016 7:49 pm
Ok, so it works if I set the input as a PULL_UP resistor, and not PULL_DOWN.
Burngate
Wed Jun 15, 2016 7:53 am
... and your button is connected between the GPIO and ground?
Return to “Python”
