cscuilla
Command line shortcut to run Python script.
Mon May 23, 2016 7:37 pm
I have a script saved at /home/pi/scripts/myscript.py..
To run the scirpt I type:
sudo python /home/pi/scripts/myscript.py
Is their a way to create a command line shortcut to run the script?
IE: I would like to simply type "myscript" in the command line to get the script to run.
Thanks for your time.
MarkHaysHarris777
Re: Command line shortcut to run Python script.
Mon May 23, 2016 7:53 pm
1) create myscript.py and place it in your PYTHONPATH---> /home/pi/Python3/
1b) create myscript_main.sh and place it in your PYTHONPATH
2) create myscript.sh and place it in your bin directory---> /home/pi/bin/
3) make the myscript.sh, myscript_main.sh file(s) executabe:
chmod 0754 /home/pi/bin/myscript.sh
chmod 0754 /home/pi/Python3/myscript_main.sh
#!/bin/sh
export PATH=$PATH:/home/pi/bin/
export PYTHONPATH=/home/pi/Python3/
exec /home/pi/Python3/myscript_main.sh
#!/usr/bin/python3
from myscript import *     <---- this imports myscript.py
rest of script goes here
notes:
1) you will have to create bin in /home/pi/
2) you will have to create Python3 in /home/pi/
3) myscript.py contains your python header information
4) /home/pi/Python3/myscript_main.sh is your main python code
5) /home/pi/bin/myscript.sh is your python environment setup code
To launch your code just type
myscript.sh
marcus
:ugeek:
tom.slick
Mon May 23, 2016 9:23 pm
Or you can just do it the linux way
2 choices
1)
Create a bash script with 2 lines in it and place it in /usr/local/bin you could call it myscript
#!/bin/bash
Then make it executable
chmod +x ~/bin/myscript
To run it just type
sudo myscript
2)
Make your script executible
chmod +x /home/pi/scripts/myscript.py
make sure to add the correct shebang line to your script
#!/usr/bin/env python2
or
#!/usr/bin/env python3
Then symlink to it
sudo ln -s /home/pi/scripts/myscript.py /usr/local/bin/myscript
To run it just type
sudo myscript
I would go for choice 2. If you ever change where myscript.py is located you just update the symlink with the new path
sudo ln -s /new/path/to/myscript.py /usr/local/bin/myscript
Also if your script is just a single file then you can move it to either /usr/local/bin or /home/pi/bin
JimmyN
Mon May 23, 2016 9:28 pm
I'd just create an alias for "myscript".
nano ~/.bash_aliases
Scroll down to the bottom and add a new alias.
alias myscript='sudo /usr/bin/python /home/pi/scripts/myscript.py &'
The next time you log in you'll be able to just type myscript to run it.
cscuilla
Mon May 23, 2016 11:06 pm
Thanks. It's working. I used the second option.. Thank you
stderr
Mon May 23, 2016 11:38 pm
JimmyN wrote:I'd just create an alias for "myscript".
If you have to type it a lot, just name it without any extension. If you go the alias route for something like this, you've created two places you need to update when you move the script to another box. And what happens if you go, gosh, I think I'll rewrite this thing in python, it's getting boring in bash? Now you've got to learn the new name!
asandford
Tue May 24, 2016 12:17 am
Aliases 'tend' to be used for system commands plus options (I have defined a 'root' alias that is 'sudo su -', 'll' which is 'ls -lrta', and 'poff' for 'sudo poweroff'') .
But I wonder why the OP needs to runs the python code as root as it can be devastating if things go wrong (as was recently demostrated by someone who wouldn't listen to the advice given)?
cscuilla
Tue May 24, 2016 12:27 am
I don't need to run as root. I guess it's a habit I should break..
Also, when I type..
I get a blank page. Is this correct?
tom.slick
Tue May 24, 2016 12:37 am
cscuilla wrote:I don't need to run as root. I guess it's a habit I should break..
Also, when I type..
Yes, it we be blank until you put your aliases in it.
stderr
Tue May 24, 2016 12:55 am
In the least, you risk ending up with permissions that make it hard to not use sudo all the time. If you are having to use sudo in the home directory of the user that you are running as, that is likely the problem.
Also, when I type..
This is because that file doesn't exist and you are creating it anew. Go look in ~/.bashrc and near the top you'll see some examples of aliases that are already available. Make some sort of change to the file and then run
exec bash
and test them out.
It would be good, though, to add a user and test in that user because if the .bashrc or any other file that runs at start up gets messed up, you might not be able to log into that account easily. The alias stuff shouldn't be a problem but if you radically mess with things, it might be.
There is also the ~/.profile file that is run under certain circumstances. You might add
echo "running the ~/.profile file"
to that file and
echo "running the ~/.bashrc file"
to that file so you can get a feel for when each is run. Note that there is a weird problem that might occur where doing this causes sftp to complain for some reason. This only happened going into Ubuntu 14.04 AMD64 but remove what I just said fixed it. If you remember that there might be some issue like that, I think it's worth it to have this in the files.
asandford
Tue May 24, 2016 1:03 am
Please do. It doesn' really matter too much on the Pi (if you don't mind trashing the whole system now and again), but I hope that people going into sysadmin roles don't think that running as root will solve all their problems - I've seen (and had to fix) a system brought down (costing £10K a minute in lost revinue) by a DBA running a 'cleanup' script as root which wiped most of the database (a typo in a variable name) left me facing loads of people city-types literally screaming at me to restore it.
Aydan
Wed May 25, 2016 10:06 am
cscuilla wrote:I have a script saved at /home/pi/scripts/myscript.py..
Do you have
#!/usr/bin/python
as a first line in you script?
This will tell the shell which interpreter to start the script with.
Add execute rights as appropriate (chmod ug+x myscript.py allows user and group to execute the script)
Now you can just type
./myscript
from /home/pi/scripts
if you want to be able to run it with just "myscript.py" then move it into e.g. /usr/bin (basically any path that is part of PATH)
Regards
Aydan
Wed May 25, 2016 5:41 pm
Aydan wrote:Do you have
#!/usr/bin/python
./myscript
Yes, but that won't run the script using sudo.
There are various methods you can use.
Create a new directory (if it doesn't exist) call "bin" in your home directory. Next time you log in that will be in your PATH.
Create a script in that directory (nano bin/myscript) like this
#!/bin/bash
Make it executable
chmod +x bin/myscript
That should do it.
The other method is to set up a command alias
alias myscript="sudo python /home/pi/scripts/myscript.py
but that will only last until you log out again. Make it permanent by creating a file called .bash_aliases
Then logout and in again and when you type "alias" you should see your command.
pi@raspi3 ~ $ cat .bash_aliases
alias myscript="sudo python /home/pi/scripts/myscript.py"
pi@raspi3 ~ $ alias
alias egrep='egrep --color=auto'
alias fgrep='fgrep --color=auto'
alias grep='grep --color=auto'
alias ls='ls --color=auto'
alias myscript='sudo python /home/pi/scripts/myscript.py'
pi@raspi3 ~ $ myscript
python: can't open file '/home/pi/scripts/myscript.py': [Errno 2] No such file or directory
My Pi gives an error because I don't have a file called /home/pi/scripts/myscript.py, but yours should work.
Wed May 25, 2016 6:22 pm
Easiest way to run python program with sudo is to change the shebang line from
#!/usr/bin/python3
to
#!/usr/bin/sudo /usr/bin/python3
make the script executable and it will run as root.
MarkHaysHarris777
Wed May 25, 2016 6:41 pm
tom.slick wrote:Or you can just do it the linux way ...
ha! oh tom, that's like saying there's a Legos way of stacking plastic blocks!
:lol:
gnu+linux = infinite configurability | unlimited flexibility
marcus
:ugeek:
e-raser
Sun Aug 21, 2016 3:44 pm
rpdom wrote: The other method is to set up a command alias
pi@raspi3 ~ $ alias
I´m into creating some alias permanent. But it unfortunately does not work (running on Raspbian = Debian Jessie). Whenever a new SSH session is opened, there is no alias anymore. So it is NOT PERMANENT :( Any ideas?!? Should I open a new topic for this?
1x Nextcloud & Pi-hole & ... on Raspbian @ Pi (4 4 GB)
1x Kodi media center on LibreELEC @ Pi 3 B+
Return to “Python”
