objectR
Using pySerial
Mon May 23, 2016 4:24 am
I tried using pySerial with my RPi2, sending data out to the /dev/AMA0 port. However, after like 2 seconds of sending data, it just got stuck. The code works 100%, tested it on Ubuntu and OSX where it worked as expected.
Do I have to edit boot/cmdline or similar files to make it work?
thank you!
objectR
Re: Using pySerial
Wed Jun 01, 2016 1:14 am
no one had this problem before?
stevech
Re: Using pySerial
Wed Jun 01, 2016 7:27 pm
no such problem here. Be sure to disable hardware flow control. And change the OS config to not have a login terminal on that serial port.
objectR
Re: Using pySerial
Tue Jun 21, 2016 7:51 pm
Can you give me a hint on how to do that? thank you
Return to “Python”
