murkata86
Displaying Sensor Readings in a Web Page
Sun May 15, 2016 11:01 pm
Hi All,
I have Raspberry Pi 2 with Raspbian OS. Recently I've purchased the Adafruit MCP9808 temperature sensor and wired it to the Pi. I've downloaded the library Adafruit has provided:
https://learn.adafruit.com/mcp9808-temp ... y/software
Everything is working fine, but I want to display the sensor readings in a web page and temperatur should be dynamically updated.
Does anyone know how this can be done or is there a similar example?
Thanks for your help!
Regards,
Ivan
coltonj96
Re: Displaying Sensor Readings in a Web Page
Mon May 16, 2016 2:02 am
One way is to output the data from the sensors to a sqlite or sql database via Python and have an AJAX enabled webpage retrieve and update the info on the page
murkata86
Mon May 16, 2016 6:42 am
Thank you for your response!
I was thinking about this as well, but won't this cause some performance issues as Python will be writing to the database while the app is running and with AJAX will be querying all the time as well.
I've shared my problem with a friend of mine and he mentioned something about sockets and I've checked in the Internet (as I'm not aware of the sockets at all), but all the examples were not working for me...
dddomodossola
Mon May 16, 2016 6:57 am
Hello murkata86,
have you seen this library https://github.com/dddomodossola/remi ?
This allows to build a webinterface simply, without writing html and javascript. ;)
murkata86
Mon May 16, 2016 7:37 am
Well the thing is that at some point I'll need to write JavaScript and PHP....
dddomodossola
Mon May 16, 2016 7:44 am
Why you plan to use javascript or PHP?
murkata86
Mon May 16, 2016 8:42 am
Because I want to build a more complex web interface and I think with JavaScipt and PHP I'll have more flexibility. Right now what I need is just to send data from Python to JavaScript or PHP, but after that I'll need to send data from JavaScript and/or PHP to Python as well. So basically the Python app will be sending and receiving data to and from PHP and/or JavaScript.
tom.slick
Mon May 16, 2016 8:51 am
murkata86 wrote:Thank you for your response!
For only a handful of sensors (20 or so) would not be a performance issue, even for a model A. You would still have a large overhead to work with.
Sockets will work, but that's a lot of work for what you want and there are easier ways to do it.
@dddomodossola suggest his remi module.
It will do what you want and is easy to use.
web.py is another option, http://webpy.org/
You write a little more code but it is way more flexible.
Some php with Apache, nGenx, or Lighttpd are the most complicated, but offer the most customization, but can also be the simplest way to go.
If you just want to get it done then follow one of the many tutorials for installing Apache and php, write a simple php script that calls your python script and outputs your results.
<?php
    $output = shell_exec("your_script.py");
    echo "output :".$output.;
murkata86
Mon May 16, 2016 7:07 pm
Thanks! I'll look into webpy soon and will come back if I need more help.
duckvader
Tue May 24, 2016 1:11 am
I am currently using two Dallas 1-wire temp probes to read the outside temp as well as the temp of my pool water. The python script below reads the temp sensors and then converts it from C to F then inputs that data it into a mysql DB and at that point I just pull all the data via PHP on my website. It works really well.
#!/usr/bin/python
import os
import time
import datetime
import glob
import MySQLdb
from time import strftime
#Uncomment for Live Temp Sensors
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
#Live Temp Sensors
poolTempSensor = '/sys/bus/w1/devices/28-0214632d15ff/w1_slave'
outsideTempSensor = '/sys/bus/w1/devices/28-03146315efff/w1_slave'
#Test Temp Sensors
#poolTempSensor = '/opt/code/tempSensor/devices/28-000003cee4ca/w1_slave'
#outsideTempSensor = '/opt/code/tempSensor/devices/28-000003cee5ca/w1_slave'
# Variables for MySQL
db = MySQLdb.connect(host="localhost", user="XXXXXX",passwd="XXXXXX", db="XXXXXX")
cur = db.cursor()
#Reading Pool Temp Data
def readPoolTempRaw():
    pt = open(poolTempSensor, 'r')
    lines = pt.readlines()
    pt.close()
    return lines
def readPoolTemp():
    lines = readPoolTempRaw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    poolTemp = lines[1].find('t=')
    if poolTemp != -1:
        tempString = lines[1][poolTemp+2:]
        poolTempC = float(tempString) / 1000.0
        poolTempF = poolTempC * 9.0 / 5.0 + 32.0
        return ("%.f" %poolTempF)
#Reading Outside Temp Data
def readOutsideTempRaw():
    ot = open(outsideTempSensor, 'r')
    lines = ot.readlines()
    ot.close()
    return lines
def readOutsideTemp():
    lines = readOutsideTempRaw()
        time.sleep(0.2)
    outsideTempOutput = lines[1].find('t=')
    if outsideTempOutput != -1:
        tempString = lines[1][outsideTempOutput+2:]
        outsideTempC = float(tempString) / 1000.0
        outsideTempF = outsideTempC * 9.0 / 5.0 + 32.0
        return ("%.f" %outsideTempF)
while True:
        #print (readPoolTemp())
        #print (readOutsideTemp())
        poolTemp = readPoolTemp()
        outsideTemp = readOutsideTemp()
        datetimeWrite = (time.strftime("%Y-%m-%d ") + time.strftime("%H:%M:%S"))
        # SQL Statement
        sql = ("""INSERT INTO tempLog (dateTime,poolTemp,outsideTemp) VALUES (%s,%s,%s)""",(datetimeWrite,poolTemp,outsideTemp))
        # Execute the SQL command
        cur.execute(*sql)
        # Commit your changes in the database
        db.commit()
        #cur.close()
        #db.close()
        time.sleep(3600)
Gavinmc42
Tue May 24, 2016 2:41 am
I save temperature data to a log.csv file.
Then have a web server running this javascript
http://dygraphs.com/
It is just some simple HTML5 with one js file running on busybox-httpd server.
I'm dancing on Rainbows.
clemaez
Thu May 26, 2016 8:17 pm
A more effective way would be to use a Websocket. Just send a JSON formatted string that way you can easily parse it on Javascript side.
Your application architecture should look like:
server.py:
- Create a web socket server
- Create a loop who read your sensor regularly
- Format the data as a JSON formatted string (i.e: {"temperature": 0, "pressure": 0, "altitude": 0}
- Send this string to all Websocket client
Your web-application:
- Create a Websocket client
- Connect it to your websocket server
- Parse the receive data (i.e JSON.parse(data))
- Display them on your page
For Websocket server on python I would recommend http://websockets.readthedocs.io/en/stable/
And for Websocket client there is nothing specific, any recent web browser provides Websocket implementation (a documented websocket client is available in my previous link)
Kind regards,
Clément
texy
Fri May 27, 2016 1:15 pm
murkata86 wrote:Hi All,
Regards,
Ivan
The Foundations weather station does exactly what you want - you'll need to change it for the particular sensors you are using of course.
The setup for the sensors is here :
https://www.raspberrypi.org/learning/we ... e-setup.md
The setup for the webpage is here :
https://www.raspberrypi.org/learning/we ... mo-site.md
Hope this helps,
Texy
Return to “Python”
