addeswe
Capture screen of Firefox
Wed May 11, 2016 6:41 am
Hi. So I'm trying to capture the screen of a firefox (this can actually be changed to chrome, libre office whatever).
Is there a library that allows you to do this? (pid-based or whatever) And is it possible also to this while the window is minimized?
With a little luck, somebody has done this before and knows a way to do it!
“Knock, knock.” - “Who’s there?” - very long pause…. - “Java.”
If a python knocks on your door and says “Hi, I’m a vacuum cleaner!” it’s not true. That’s a python.
MarcScott
Re: Capture screen of Firefox
Wed May 11, 2016 7:21 am
Are you looking for a way to do this with Python? If so you might like to check out https://pypi.python.org/pypi/pyscreenshot
If not then scrot is a quite popular command line tool for screenshots, although I prefer to use imagemagick - both of which could be called via os.system.
With a minimised window this becomes a little trickier. If it's just the a webpage that you want to capture then you could use phantomJS http://phantomjs.org/ I suppose.
addeswe
Wed May 11, 2016 8:14 am
Thanks for the reply MarcScott.
At the moment, I'm using pyscreenshot. What I am doing is to capture part of the screen with a bbox. Then reads the r,g,b-values of the pixels. The problem is that sometimes a terminal window gets in the way or I have to swap to another fullscreen application. And then the values are wrong.
So that is why I want to find something that takes a "screengrab" of a pid or a defined window, preferably in minimized state.
MarcScott
Wed May 11, 2016 11:05 am
I don't know how helpful this will be but:
You can get a window ID and associated PID with
 wmctrl -lp
You can then use imagemagick to capture the screen, even when it's minimised.
So you should be able to use subprocess to get the results of wmctrl and then pass it all over the wanted id to imagemagick.
I could probably knock some code together later today if you get stuck.
addeswe
Wed May 11, 2016 1:15 pm
I don't really have any problems with subprocess and I've used it for other projects, but thanks anyways! My only problem with this is that i need to use tmpfs where I save the imagefile if I use it for my project. The software is running checks more then once a second. So that is why I wanted to put the data into the memory instead of memory card. I guess that I'm semi satisfied with the help. Even though, I would be happy if anyone have a better way to do this? :-)
stderr
Wed May 11, 2016 2:51 pm
addeswe wrote: I guess that I'm semi satisfied with the help. Even though, I would be happy if anyone have a better way to do this? :-)
Well, you know, you do get what you pay for. In any case, one option given was phantomjs which certainly can be used to render webpages and save them to a tmpfs. This isn't going to help you with taking pictures of other applications but it is a powerful capability.
addeswe
Wed May 11, 2016 2:57 pm
My intention was never to sound ungrateful. However phantomjs won't really be the solution to my problem since i read pixeldata. If I offended anyone by saying that "I guess that I'm semi satisfied with the help", I apologize. It was my way of saying that it is a solution but not really the one I would prefer!
Return to “Python”
