Exiting my Tkinter window w/ switch
Posted: Mon Apr 18, 2016 9:27 pm
by Cowardlydoomsday
I am writing a script where I need a physical button to exit out of the Tkinter window my script has created. Below is my script:
import RPi.GPIO as GPIO
import os as sysCmd
import Tkinter as tk
from Tkinter import *
import ttk
import time
import picamera
import datetime
from PIL import Image
## GPIO settings
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(12, GPIO.IN, pull_up_down = GPIO.PUD_UP)
GPIO.setup(10, GPIO.OUT)
GPIO.setup(16, GPIO.OUT)
GPIO.output(10, GPIO.HIGH)
## Call picamera and settings
camera = picamera.PiCamera()
camera.hflip = True
camera.vflip = True
camera.resolution = (800, 480)
debounce = .25
delay = 3
## Physical button switch to exit out of program but leave RPi on
def ButtonSwitch():
    while GPIO.input(12) == 0:
        time.sleep(0.25) ## Debounce
        start_time = time.time()
            if time.time() - start_time > delay - debounce:
                print("Button was Pressed")
                #sysCmd.system('sudo killall idle')
                self.quit()
    root.after(3000, ButtonSwitch)
## Initiate the GUI and widgets
class MainScreen(Frame):
    def __init__(self, parent):
        tk.Frame.__init__(self, parent)
        self.createWidget()
    ## Creating buttons
    def createWidget(self):
        self.pack()
        bttn1 = tk.Button(self, text = "LEDS"   , command = self.LEDs).grid   (row = 1, column = 1, pady = 5, padx = 5)
        bttn2 = tk.Button(self, text = "Quit"   , command = self.quit).grid   (row = 2, column = 1, pady = 5, padx = 5)
        bttn3 = tk.Button(self, text = "Capture", command = self.takePic).grid(row = 3, column = 1, pady = 5, padx = 5)
    ## Turning on and off LED's
    def LEDs(self):
        GPIO.output(16, GPIO.HIGH)
        time.sleep(2.5)
        GPIO.output(16, GPIO.LOW)
        #time.sleep(2.5)
    ## Setting up time stamp
    def takePic(self):
        now = datetime.datetime.now()
        dateTimeStamp = now.strftime('%Y%m%d-%H%M%S')
        global photoName
        photoName = dateTimeStamp + ".jpg"
    ## Taking picture with datetime stamp
        try:
            camera.start_preview()
            camera.annotate_background = picamera.Color('blue')
            camera.annotate_text = datetime.datetime.now().strftime('%Y-%m-%d %H:%M:%S')
            time.sleep(5)
            camera.stop_preview()
            self.fileName = photoName
            camera.capture(self.fileName)
        finally:
            camera.close()
    ## Overlaying the watermark onto the original image
        basePic = (self.fileName)
        watermarkPic = 'Overlay.png'
        base = Image.open(basePic)
        watermark = Image.open(watermarkPic)
        xyoffset = (0, 240)
        base.paste(watermark, xyoffset, mask = watermark)
        base.save(self.fileName)
## Mainloop
root = tk.Tk()
MainScreen(root)
root.geometry('125x125+25+25')
root.mainloop()
root.destroy()
'sudo killall idle will close the python script but not the tk window. Is there a terminal command that will close just the window I specify?
Re: Exiting my Tkinter window w/ switch
Posted: Mon Apr 18, 2016 10:41 pm
by Davies
Hi, im fairly new to python and certainly not the best to be giving answers but i did notice an error in your code that i had also made recently..
in def ButtonSwitch(): you finish a while: with a root.after this would open multiple instances and cause the code to crash over time, it wants to have a time.sleep(3) rather than the root.after and allow the while to handle the continuous running. also id open it in a thread rather than a root.after but there are probably better ways.
also i dont think it wants the root.destroy at the end, that is infact the code to close the tkinter window your asking about.
theres probably better ways to do this but see here on this tkinter numpad code, the numpad opens in a seperate window to the main and is opened as boot rather than root, then boot.destroy is called to close that window while leaving root open..
from functools import partial
root = tk.Tk()
root.geometry("200x100")
num_run = 0
btn_funcid = 0
def click(btn):
    global num_run
    text = "%s" % btn
    if not text == "Del" and not text == "Close":
        e.insert(END, text)
    if text == 'Del':
        e.delete(0, END)
    if text == 'Close':
        boot.destroy()
        num_run = 0
        root.unbind('<Button-1>', btn_funcid)
def numpad():
    global boot
    boot = tk.Tk()
    boot['bg'] = 'green'
    lf = tk.LabelFrame(boot, text=" keypad ", bd=3)
    lf.pack(padx=15, pady=10)
    btn_list = [
        '7',  '8',  '9',
        '4',  '5',  '6',
        '1',  '2',  '3',
        '0',  'Del',  'Close']
    r = 1
    c = 0
    n = 0
    btn = list(range(len(btn_list)))
    for label in btn_list:
        cmd = partial(click, label)
        btn[n] = tk.Button(lf, text=label, width=10, height=5, command=cmd)
        btn[n].grid(row=r, column=c)
        n += 1
        c += 1
        if c == 3:
            c = 0
            r += 1
def close(event):
    global num_run
    if num_run == 1:
        boot.destroy()
        num_run = 0
def run(event):
    global num_run, btn_funcid
    if num_run == 0:
        num_run = 1
        numpad()
        btn_funcid = root.bind('<Button-1>', close)
e = Entry(root, width=10, background='white', textvariable=file, justify=CENTER, font='-weight bold')
e.bind('<Button-1>', run)
e.grid(padx=10, pady=5, row=17, column=1, sticky='W,E,N,S')
root.mainloop()
Posted: Mon Apr 18, 2016 11:22 pm
by Cowardlydoomsday
Thanks for your replay. I might of not made it clear but I do want this button to close the Tkinter window. I have another program running right now that is basically the same block that shuts down my PI after the button is held down for 3.5 seconds. And I have no problems with that. The self.quit line in the block was a trial that failed and I just forgot to take it out. I do have a button that appears in the window to exit the program, hence the reason for the root.destroy in the root window.
Posted: Mon Apr 18, 2016 11:53 pm
by Davies
i misread the indentation on that root.after, it wouldnt cause the problem i suggested.
so are you saying you want to close the tkinter window but keep some of the script code running? rather than calling root.destroy and closing tkinter and root?
Posted: Tue Apr 19, 2016 12:00 am
by Cowardlydoomsday
I actually got it to work! When the button is pressed for 3 to 4 seconds, the program calls on a terminal command of "sudo killall python". Then it closes the python shell which in turns closes the tkinter window.
import os as sysCmd
import ttk
import time
import picamera
import datetime
## GPIO settings
camera.hflip = True
camera.vflip = True
debounce = .25
delay = 3
def ButtonSwitch():
                sysCmd.system('sudo killall python')
        self.createWidget()
    ## Creating buttons
        self.pack()
    def LEDs(self):
        time.sleep(2.5)
        #time.sleep(2.5)
    def takePic(self):
        global photoName
        try:
            time.sleep(5)
        finally:
            camera.close()
        xyoffset = (0, 240)
## Mainloop
root = tk.Tk()
MainScreen(root)
root.mainloop()
root.destroy()
Hope this will help you in any future development.
Posted: Tue Apr 19, 2016 1:20 am
by tom.slick
Try this
import os as sysCmd
import ttk
import time
import picamera
import datetime
## GPIO settings
camera.hflip = True
camera.vflip = True
debounce = .25
delay = 3
        self.root = parent
        self.createWidget()
        self.root.after(3000, self.ButtonSwitch)
    def ButtonSwitch(self):
                    self.root.destroy()
    ## Creating buttons
        self.pack()
    def LEDs(self):
        time.sleep(2.5)
        #time.sleep(2.5)
    def takePic(self):
        global photoName
        try:
            time.sleep(5)
        finally:
            camera.close()
        xyoffset = (0, 240)
## Mainloop
root = tk.Tk()
MainScreen(root)
root.mainloop()
Posted: Tue Apr 19, 2016 3:55 pm
by Cowardlydoomsday
tom.slick, the code you gave me did not work. gave an error of the "ButtonSwitch" needs to be a global.
Posted: Tue Apr 19, 2016 7:31 pm
by tom.slick
Sorry I forgot to change something.
I edited the original post, it should work now
