Johnny5C
Parsing NMEA strings with pynmea2
Sat Apr 02, 2016 9:24 pm
Hi forum folk.
I have hooked up a microstack GPS receiver to my B+, and can see the NMEA data using cat /dev/ttyAMA0, so the connections are OK . I found the parsing example below and the next step was to adapt it to my means, but it does not run.
import serial
import pynmea2
def parseGPS(str):
    if str.find('GGA') > 0:
        msg = pynmea2.parse(str)
        print "Timestamp: %s -- Lat: %s %s -- Lon: %s %s -- Altitude: %s %s" % (msg.timestamp,msg.lat,msg.lat_dir,msg.lon,m$
serialPort = serial.Serial("/dev/ttyAMA0", 9600, timeout=0.5)
while True:
    str = serialPort.readline()
    parseGPS(str)
File "app2.py", line 7
print "Timestamp: %s -- Lat: %s %s -- Lon: %s %s -- Altitude: %s %s" % (msg.timestamp,msg.lat,msg.lat_dir,msg.lon,msg.lon_dir,msg.altitude,msg.altitude_units)
SyntaxError: invalid syntax
I have done a fair but of reading, but I cant see any obvious syntax issues?
Any help would be appreciated.
scotty101
Re: Parsing NMEA strings with pynmea2
Sat Apr 02, 2016 9:54 pm
Which version of python are you using?
In Python 3 print is a function e.g.
print("hello") not print "Hello"
DirkS
Sat Apr 02, 2016 9:56 pm
The position of the caret is relevant. I would say the problem is in the format string.
Looking at https://github.com/Knio/pynmea2 my first suspect would be the formatting of the first parameter.
Apparently it's not a string, but a datetime variable.
I'm not sure if you can use date format parameters with % formatting. Maybe you have to convert it to a string first
I think 'format' is more flexible than '%' (see e.g. https://pyformat.info/ or https://docs.python.org/2/library/strin ... ing-syntax)
Johnny5C
Sun Apr 03, 2016 12:29 pm
Thanks for the quick replies. I have a few things to try now.
For info I'm running a fresh install of Jessie on a B+
And, when launching the python script it with sudo python script.py it cant import serial. I tried with python3 and it gets as far as the error above, and it then i got stuck.
**On edit, it appears its tripping over import serial, so is there something different in Jessie?**
Cheers
Return to “Python”
