devenh
pygame.mixer.music.queue not working for me!
Mon Mar 28, 2016 2:49 pm
I'm sure I'm missing something simple, but I just can't get the queue function to work. I'm using Python 3.4.2 under the latest Jessie release on a Pi 3. I have tested with wav and ogg files.
PATHAUDIO = '/home/pi/Music/'
ext = '.ogg'
print(ext)
pygame.mixer.init()
pygame.mixer.music.load(PATHAUDIO + 'first' + ext)
pygame.mixer.music.play(2)
pygame.mixer.music.queue(PATHAUDIO + 'second' + ext)
#pygame.mixer.music.play()
print('done')
The first audio file gets played three times, but the second one is never played.
elParaguayo
Re: pygame.mixer.music.queue not working for me!
Wed Mar 30, 2016 7:00 pm
Can you verify that the second file plays through pygame?
Also, how are you running this code? If you execute it as a python script then, without some loop at the end, the code will just exit.
I don't have a pi that I can easily test this on. However, I've tested it on my laptop (Ubuntu) and it works as expected for me.
This was the code I ran:
import pygame
import time
mix = pygame.mixer  # This is just me being lazy!
music = mix.music  # ditto
f1 = "/usr/share/sounds/alsa/Front_Center.wav"
f2 = "/usr/share/sounds/alsa/Front_Left.wav"
mix.init()
music.load(f1)
music.play(2)
music.queue(f2)
print "Done"
time.sleep(15)
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
devenh
Sat Apr 02, 2016 1:14 pm
elParaguayo wrote:Can you verify that the second file plays through pygame?
Yes it does.
I thought the same thing and had already tried adding sleep(20), but same result.
It appears the problem is pi specific as the code works on your laptop.
devenh
Sun May 22, 2016 5:13 pm
If pygame.mixer.music.queue does not work, can anyone suggest an alternative python library that has the ability to queue music in a non blocking fashion?
Nebi
Sat Oct 14, 2017 10:13 pm
it was dissolved! click here [-----> que.py you can download and edit the file!
this code can help you!
        import pygame, time
        from tkinter import *
        root = Tk()
        c = ["music1.mp3", "music2.mp3", "music3.mp3"] #you can add more
        x = 0
        def music():
           pygame.init()
           pygame.mixer.init()
           pygame.mixer.music.load(c[x])
           pygame.mixer.music.play(0)
           que()
        def que():
           global x, c
           pos = pygame.mixer.music.get_pos()
           if int(pos) == -1:
              x += 1
           root.after(1000, que)
        music()
        root.mainloop()
Nebi
Sat Oct 14, 2017 10:30 pm
it was dissolved! click here: que.py you can download and edit the file!
    import pygame, time
    root = Tk()
    x = 0
    def music():
       pygame.init()
       pygame.mixer.init()
       que()
    def que():
       global x, c
       if int(pos) == -1:
          x += 1
    music()
    root.mainloop()
Return to “Python”
