Matt1234
Python GPIO library problems...
Fri Aug 10, 2012 5:53 am
I am trying to install the python GPIO libary on my raspberry pi... I am following the meet the rapsberry pi book at the moment and so don't understand why it is going wrong. What is going wrong though is when I try to do 'sudo python setup.py install' ( this is to install the libary in python) I get tonnes of error messages. All other steps i think were completed successfully. The only thing that I am doing different from the book is the release number. In the book it is -0.2.0 I am putting in -0.3.1a.
Can somebody PLEASE help me!
texy
Re: Python GPIO library problems...
Fri Aug 10, 2012 6:23 am
Not seen the book, but you'll need to show us a screen dump of the error messages in order to give help ;)
T.
matthewtb
Fri Aug 10, 2012 7:02 am
Okay here you are this what happens when you type : sudo python setup.py install
:roll:
here you go TONNES of errors
matthewtb
Fri Aug 10, 2012 7:08 am
Jesus wrong picture SORRY... here is the proper one...
:oops:
For some reason I cant upload the picture so I will write what it says:
source/py_gpio.c:250: error: expected '=' , ' ,' ,' ,',; 'asm' or '_attribute_' be
That line is repeated multiple times with slight variations... I am running debian at the moment will upgrade to raspbian soon though!
texy
Fri Aug 10, 2012 7:11 am
...so have 2 Matthews with the same problem ;)
T.
croston
I can't see your screenshot but have you done:
sudo apt-get install python-dev python3-dev
(before installing module)
matthewtb
Fri Aug 10, 2012 8:02 am
When I type in your command it comes up with the good ol' 404 error... What should I do now?
matthewtb
Fri Aug 10, 2012 8:41 am
Got any ideas? :)
texy
Fri Aug 10, 2012 9:51 am
Is your pi connected to the Internet ?
Can you try
Sudo apt-get update
Sudo apt-get upgrade
Then try croston's commands.
T.
MattHawkinsUK
Fri Aug 10, 2012 9:55 am
Within Raspbian I use :
wget http://raspberry-gpio-python.googlecode.com/files/python-rpi.gpio_0.3.1a-1_armhf.deb
then :
sudo dpkg -i python-rpi.gpio_0.3.1a-1_armhf.deb
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
Return to “Python”
