Trying to learn classes
Posted: Sun Mar 20, 2016 4:29 am
by spleen21
Hi everyone,
Im new to Python and trying to teach myself how to use classes. Im simply trying to load a white box using pygame from within a class so that i can eventually pass text to it. Problem is, for the life of me, i can't even draw a white box. I've tried all sorts of combinations but just keep getting error after error.
Ive can use pygame fine without using classes but just cant get anything to work while using them.
The code below tells me that there is no attribute called "screen". Did i not define it at the start?
Can someone please point me in the right direction?
import pygame
pygame.init()
white = (255, 255, 255)
screen = pygame.display.set_mode((800, 480))
class home():
    def __init__(self):
        self.screen.fill(white)
def main():
    runProgram = True
    clock = pygame.time.Clock()
    pygame.display.update()
    while runProgram:
        clock.tick(60)
        for event in pygame.event.get():
            if event.type == pygame.QUIT:
                runProgram = False
        home()
main()
pygame.quit()
Re: Trying to learn classes
Posted: Sun Mar 20, 2016 8:56 am
by scotty101
In the scope of your class there isn't an attribute called screen.
You can either initially define the screen inside your class as self.screen or pass screen to the class initialise function. Or just use screen not self.screen.
If you want some examples of classes in pygame and python, try this code that I was involved in a few years ago
https://github.com/scotty3785/python-ai ... ic-control
