ImportError: No module named 'gobject'
Posted: Fri Mar 18, 2016 5:20 pm
by AndressaSiq
I'm new in Python and I saw this Error:
ImportError: No module named 'gobject'.
I don't know what I need to do for my script work. I need help.
Re: ImportError: No module named 'gobject'
Posted: Fri Mar 18, 2016 7:20 pm
by Douglas6
Where did you find the code you are trying to run? There may be instructions for installing prerequisites. If you are new to Python, using gobject may be a little advanced for you.
Posted: Sun Mar 20, 2016 2:30 pm
by AndressaSiq
Hi Douglas,
I found the code in this page... https://github.com/dixel/wifi-linux
And I didn't find any instructions for installing....
Posted: Sun Mar 20, 2016 3:32 pm
by Douglas6
AndressaSiq wrote:Hi Douglas,
You're right. Gobject (and dbus and glib) are installed in Raspbian by default, but only for Python 2. You'll probably find other issues, so make sure you are running that code with Python 2.
sudo python2 list_rssi.py
Posted: Sun Mar 20, 2016 3:36 pm
by AndressaSiq
I will try this!!! Thanks a lot Douglas!!!! :)
Posted: Mon Mar 21, 2016 12:00 pm
by AndressaSiq
Hi Douglas,
This code worked in Python2. I only need to install gnuplot-py before.
Thanks a lot your help!
