pootle
function call as a parameter default only gets called once
Mon Feb 29, 2016 8:53 am
Just a behaviour I find slightly strange. An explanation of why the language behaves this way could be enlightening.
I made the default value of a parameter in a function definition a function call. I find in practice that this only gets evaluated the first time the function is called, so ended up defaulting to None with a test and call in the code.
def nicetimeinterval(timethen, timenow=time.time())
diff = int(timenow-timethen
This results in time.time() only being called once, with all subsequent calls picking up the value from the first call. Clearly not what I was expecting!
This is with Python 3
joan
Re: function call as a parameter default only gets called on
Mon Feb 29, 2016 9:22 am
That is documented behaviour. At least I remember reading about it when I was checking on default parameters.
RogerW
Mon Feb 29, 2016 9:42 am
Yes (to my surprise) it is documented. This is from the 3.4.3 documentation.
Default parameter values are evaluated from left to right when the function definition is executed. This means that the expression is evaluated once, when the function is defined, and that the same “pre-computed” value is used for each call. This is especially important to understand when a default parameter is a mutable object, such as a list or a dictionary: if the function modifies the object (e.g. by appending an item to a list), the default value is in effect modified.
pootle
Mon Feb 29, 2016 12:24 pm
Aha, thanks very much. not what (was to me at least) the intuitive answer, but if that's what it says on the tin!...
elParaguayo
Mon Feb 29, 2016 12:29 pm
The way this is typically dealt with (in my experience at least) is to have a default value of None and then, in the method itself, test if the parameter is None and then set the default variable at that stage.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
