spbach1234
Python CGI Script
Sun Feb 21, 2016 1:00 pm
Hello, I am trying to make a webserver on the raspberry pi, that when you press a key on the keyboard, the webpage toggles a boolean in the script. However, I am stumped on what to do. I am using lighthttpd for the server.
Thanks,
-Spbach
elatllat
Re: Python CGI Script
Sun Feb 21, 2016 2:40 pm
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
spbach1234
Sun Feb 21, 2016 5:42 pm
Huh? how do I find that out?
mysen
Mon Feb 22, 2016 12:08 am
i believe that was a suggestion...
i'm not sure about lighthttpd but, with apache2 you can put your python code in the cgi-bin and have it out put the html with ajax with in it. it's a bit tricky to get going but simple once you understand it.
It all starter here: http://www.google.co.uk/
good luck!
dddomodossola
Mon Feb 22, 2016 6:02 am
Maybe you can use REMI (RemoteInterface) https://github.com/dddomodossola/remi
With this library you can create webinterfaces for your scripts, and you don't need to install webservers or something else because it's all integrated.
spbach1234
Tue Feb 23, 2016 12:20 pm
mysen wrote:i believe that was a suggestion...
good luck!
I think the link you put is broken, can you repost it?
ghans
Tue Feb 23, 2016 12:50 pm
I would suggest using Remi too - it seems to take care of all that AJAX business so you can concentrate on your main logic.
ghans
Return to “Python”
