Python problem on Octoprint install
Posted: Sun Feb 14, 2016 9:09 pm
Hi all.
As I want to use my raspberry pi 2 to control my 3d printer, and still use ubuntu mate, I tried to follow this tutorial:
https://github.com/foosel/OctoPrint/wik ... g-Raspbian
I installed python 2.7.1, got the octoprint package, but when lauching the command "./venv/bin/python setup.py install" I get errors, and my linux level is not high enough to find out where the problem comes from.
It would be nice if someone could help me to understand.
commands used:
errors::
commands used:
cd ~
sudo apt-get install python-pip python-dev python-setuptools python-virtualenv git libyaml-dev build-essential
git clone https://github.com/foosel/OctoPrint.git
cd OctoPrint
virtualenv --system-site-packages venv
mkdir ~/.octoprintCode: Select all
running install
File "setup.py", line 157, in <module>
setup(**params())
File "/usr/local/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/local/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/home/fab/OctoPrint/venv/lib/python2.7/site-packages/setuptools/command/install.py", line 67, in run
self.do_egg_install()
File "/home/fab/OctoPrint/venv/lib/python2.7/site-packages/setuptools/command/install.py", line 103, in do_egg_install
cmd.ensure_finalized() # finalize before bdist_egg munges install cmd
File "/usr/local/lib/python2.7/distutils/cmd.py", line 109, in ensure_finalized
self.finalize_options()
File "/home/fab/OctoPrint/venv/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 287, in finalize_options
'install_lib', ('install_dir', 'install_dir')
File "/usr/local/lib/python2.7/distutils/cmd.py", line 298, in set_undefined_options
src_cmd_obj.ensure_finalized()
File "/home/fab/OctoPrint/venv/lib/python2.7/site-packages/setuptools/command/install_lib.py", line 17, in finalize_options
self.set_undefined_options('install',('install_layout','install_layout'))
File "/usr/local/lib/python2.7/distutils/cmd.py", line 302, in set_undefined_options
getattr(src_cmd_obj, src_option))
File "/usr/local/lib/python2.7/distutils/cmd.py", line 105, in __getattr__
raise AttributeError, attr
AttributeError: install_layout
