I am using picamera python module to capture frames from RPi and then feed it to a gstreamer pipeline.
The working principle is to capture frames in a "custom output" object that has its write method. In this method, the buffer is pushed in to a gstreamer pipeline using an "appsrc" element. The code goes like this:
class CamStreamer(object):
def __init__(self,videoFormat,resolution,framerate):
self.size = 0
self.capstring = 'video/x-'+videoFormat+',width='+str(resolution[0]) \
+',height='+str(resolution[1])+',framerate=' \
+str(framerate)+'/1'
self.playing = False
self.paused = False
self.make_pipeline()
self.play_pipeline()
def make_pipeline(self):
CLI = [
'appsrc name="source" ! ',
'h264parse ! video/x-h264,stream-format=avc ! ',
'h264parse ! video/x-h264,stream-format=byte-stream ! ',
'mpegtsmux ! filesink name="sink"'
gcmd = "".join(CLI)
self.pipeline = Gst.parse_launch(gcmd)
self.filesink = self.pipeline.get_by_name("sink")
self.filesink.set_property("location","custom.ts")
self.appsrc = self.pipeline.get_by_name("source")
self.appsrc.set_property("is-live",True)
self.gstcaps = Gst.Caps.from_string(self.capstring)
self.appsrc.set_property("caps",self.gstcaps)
def play_pipeline(self):
self.pipeline.set_state(Gst.State.PLAYING)
def stop_pipeline(self):
self.pipeline.set_state(Gst.State.READY)
def write(self,s):
gstbuff = Gst.Buffer.new_wrapped(s)
ret = self.appsrc.emit("push-buffer",gstbuff)
def flush(self):
self.stop_pipeline()
class RPiCam(object):
def __init__(self):
self.resolution = (640,480)
self.bitrate = 1000000
self.format = "h264"
self.framerate = 30
self.rotation = 180
self.camera = picamera.PiCamera()
self.camera.resolution = self.resolution
self.camera.framerate = self.framerate
def startCam(self):
self.camera.start_recording(CamStreamer(self.format,self.resolution,
self.framerate),format=self.format, bitrate=self.bitrate)
def recordCam(self,duration):
self.camera.wait_recording(duration)
def stopCam(self):
self.camera.stop_recording()
def closeCam(self):
self.camera.close()
the picamera is run in a background thread using threads.defertoThread
def Record():
myCam = RPiCam()
myCam.startCam()
myCam.recordCam(5)
myCam.stopCam()
myCam.closeCam()
return True
def Complete(status):
print "Recording completed {0}".format(status)
if __name__ == '__main__':
d = threads.deferToThread(Record)
d.addCallback(Complete)
reactor.run()
Other necessary imports that are needed are:
import gi
gi.require_version('Gst','1.0')
from gi.repository import GObject, Gst, GstVideo
GObject.threads_init()
#dt.datetime.now().strftime('%d-%b-%Y %H:%M:%S')
from twisted.internet import gireactor # for non-GUI apps
gireactor.install()
Gst.init(None)
from twisted.internet import reactor, threads
import picamera
import picamera.array
And now come the question part.. I wish to generate a key frame (intra frame) request at a regular interval using mmal interface.
Any idea, how this can be achieved?
