Boxeez
Is there a way to change label fg colour with Tk?
Thu Jan 21, 2016 4:05 pm
Hi
I'd like to change the foreground of a label, when a int reaches a defined value (Button or something like this)
How does that work?
My label looks like this:
self.Label = tk.Label(self, textvariable = self.LabelText[0][0], fg=colour.get(), bg="white")
and then I try to:
colour.set("red")
That works, when I set the colour before creating the label, but I need it after that.
Thanks a lot :)
DirkS
Re: Is there a way to change label fg colour?
Thu Jan 21, 2016 4:33 pm
Please please please... if you're posting a problem, give at least some details about your setup.
From that bit of code I gather you're using tkinter with python.
mahjongg
Thu Jan 21, 2016 7:10 pm
moved to python part of forum.
Boxeez
Thu Jan 21, 2016 7:24 pm
Thank you guys for response, so sorry for that.
This is my code:
from tkinter import *
CounterValue = 0
class Application(Frame):
    def __init__(self, master):
        super(Application, self).__init__(master)
        self.grid()
        self.counter = IntVar()
        self.colour = StringVar()
        self.counter.set(0)
        self.colour.set("black")
        sButton = Button(self, border=1, text="BUTTON",command=lambda: self.CountUp())
        sButton.pack()
        sLabel = Label(self, textvariable = self.counter, fg=self.colour.get(), bg="white")
        sLabel.pack()
    def CountUp(self):
        global CounterValue
        CounterValue = CounterValue +1
        print(CounterValue)
        self.counter.set(CounterValue)
        if(CounterValue > 10):
            self.colour.set("red")
root = Tk()
app = Application(root)
root.mainloop()
RogerW
Fri Jan 22, 2016 9:47 am
You need to call the cofigure method of the button.
Try this:
CounterValue = 0
        self.grid()
        self.counter.set(0)
        #sButton = Button(self, border=1, text="BUTTON",command=lambda: self.CountUp())
        #sButton.pack()
        self.sButton = Button(self, border=1, text="BUTTON",command=lambda: self.CountUp())
        self.sButton.pack()
        sLabel.pack()
    def CountUp(self):
        global CounterValue
        print(CounterValue)
            #self.colour.set("red")
            self.sButton.configure(bg='red')
root = Tk()
root.mainloop()
Boxeez
Fri Jan 22, 2016 6:35 pm
Thank you but I'd like to change the colour from the label (from the value how may times the button was pressed). On this way will the backgroundcolour from the button change. (and not from the label under the button)
RogerW
Re: Is there a way to change label fg colour with Tk?
Fri Jan 22, 2016 6:47 pm
You can use the configure fuction on the label instead of the button.
hippy
Fri Jan 22, 2016 7:04 pm
I think what you are trying to do is have a variable which, when you change the colour name it holds, the label also changes colour much like you can do with the label text. That is achieved by tying the variable to the label using "textvariable=", but unfortunately there is no equivalent for doing that for foreground or background colour. You have to issue a .configure to change the colour.
Sat Jan 23, 2016 8:03 am
label.config(fg ='green')
should work. Obviously you'll need to change that to reference the right label object.
This is a doctor free zone.
andyj280
Fri Aug 16, 2019 4:01 am
I am trying this but it is not working for me :(. I tried calling label.update() afterwards, but that didn't work.
It might be worth mentioning that I'm calling this code from within a method/function.
Return to “Python”
