I want to be able to set a GPIO pin to high or low using a keyboard. Is this possible? If so how do I do it?
Detect keypress using Python
This signature intentionally left blank.
Re: Detect keypress using Python
Try something like that - https://stackoverflow.com/questions/240 ... -in-python
- What Can a Thoughtful Man Hope for Mankind on Earth, Given the Experience of the Past Million Years?
- Nothing.
Kurt Vonnegut, Cat's Cradle
- Nothing.
Wouldnt do anything...
Anyone else got any ideas? Tried fifty million examples allready and none work.
In pi3d we used curses. This question crops up a lot, try searching this forum with "curses getch"
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
Not sure who gets credit for the original code here, but this is what I have used in the past. Works at a Windows prompt and on Pi command line, not tested on Mac. Ctrl-C throws an exception under Windows but doesn't on the Pi.On Windows Inkey() returns a negative if no character, 0 to +N for a character, on Pi I recall it blocks until character available.
class _GetCh:
def __init__(self):
try:
self.impl = _GetChWindows()
except ImportError:
try:
self.impl = _GetChMacCarbon()
except ImportError:
self.impl = _GetChUnix()
def __call__(self):
return self.impl()
class _GetChWindows:
def __init__(self):
import msvcrt
def __call__(self):
import msvcrt
if msvcrt.kbhit():
while msvcrt.kbhit():
ch = msvcrt.getch()
while ch in b'\x00\xe0':
msvcrt.getch()
ch = msvcrt.getch()
return ord( ch.decode() )
else:
return -1
class _GetChMacCarbon:
def __init__(self):
import Carbon
Carbon.Evt
def __call__(self):
import Carbon
if Carbon.Evt.EventAvail(0x0008)[0]==0: # 0x0008 is the keyDownMask
return ""
else:
(what,msg,when,where,mod)=Carbon.Evt.GetNextEvent(0x0008)[1]
return msg & 0x000000FF
class _GetChUnix:
def __init__(self):
import tty, sys, termios # import termios now or else you'll get the Unix
# version on the Mac
def __call__(self):
import sys, tty, termios
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
try:
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ord(ch)
InKey = _GetCh()
print "Press Ctrl-C to exit"
c = InKey()
while c != 3:
if c >= 0:
print c
c = InKey()
This is the code linked to with a bit added, pressing p will toggle gpio pin 26 high and low.
import pygame, sys
from pygame.locals import *
import RPi.GPIO as GPIO
GPIO.setwarnings(False)
GPIO.setmode (GPIO.BOARD)
GPIO.setup(26, GPIO.OUT)
GPIO.output(26,GPIO.LOW)
pygame.init()
BLACK = (0,0,0)
WIDTH = 100
HEIGHT = 100
windowSurface = pygame.display.set_mode((WIDTH, HEIGHT), 0, 32)
windowSurface.fill(BLACK)
x = 0
while True:
for event in pygame.event.get():
if event.type == QUIT:
pygame.quit()
sys.exit()
if event.type == KEYDOWN:
key = event.key
if key == pygame.K_p:
if x == 0:
GPIO.output(26,GPIO.HIGH)
x = 1
else:
x = 0
Thanks guys, will try when I get a chance.
[quote="gordon77"]This is the code linked to with a bit added, pressing p will toggle gpio pin 26 high and low.
[/quote}
It worked, but not without a display connected. Maybe I should have mentioned that first. Can I trick the pi into thinking that it is connected to a screen?
import pygame, sys
pygame.init()
BLACK = (0,0,0)
WIDTH = 100
HEIGHT = 100
x = 0
while True:
pygame.quit()
sys.exit()
key = event.key
if x == 0:
x = 1
else:
x = 0
Oh wait it does work without a display. Must have stopped running the code and tries without realising... Or maybe it was just fairy magic. Thanks for the help!
