SpyderManGib
hcm5883l split the data
Sun Jan 03, 2016 3:11 pm
I have recently started using Python3 and need to extract the individual values from the command.
print(hcm5883l).
It displays something like
Bearing 232.12
Tilt 12.121
angle 3.5454
etc
How can I make those values variables so I can use them
Albert
DirkS
Re: hcm5883l split the data
Sun Jan 03, 2016 3:22 pm
Apparently you're using a module that you have downloaded from somehwere.
Do you have a link for that?
enedil
Sun Jan 03, 2016 6:18 pm
If that's a string, you can use split:
list(map(lambda p: float(p.split(' ')[1]), string.split('\n')))
- What Can a Thoughtful Man Hope for Mankind on Earth, Given the Experience of the Past Million Years?
- Nothing.
Kurt Vonnegut, Cat's Cradle
DirkS
Sun Jan 03, 2016 6:20 pm
enedil wrote:If that's a string, you can use split:
list(map(lambda p: p.split(' ')[1], string.split('\n')))
You could, but if the OP uses a downloaded module, it's likely that there are functions to get the 'raw' information.
SpyderManGib
Sun Jan 03, 2016 9:58 pm
I followed this to get ti working.
http://www.instructables.com/id/Interfa ... /?ALLSTEPS
The picture at the bottom shows the output im getting.
Any clear help would be great as im really really new to python.
Albert
Sun Jan 03, 2016 10:49 pm
So the code library you're using is https://bitbucket.org/thinkbowl/i2clibraries.git
https://bitbucket.org/thinkbowl/i2clibr ... mc5883l.py is the module reading your sensor.
SpyderManGib
Sun Jan 03, 2016 11:10 pm
DougieLawson wrote:So the code library you're using is https://bitbucket.org/thinkbowl/i2clibraries.git
Im sorry but that means nothing to me.
Does it help someone else help me separate the info I need
Albert
SpyderManGib
Sun Jan 03, 2016 11:50 pm
Although I can do something like
message2 = str(hcm5883l)
I can then not get the len(message2)
I can though use the message2[2:5]
which gives me an extract from that "string"
I have tried the spli command and it fails.
Any example I could use to split the message2 string wherever it has a carriage return and return
X,Y,Z,Beating
Would be great.
Keep in mind I have very little experience in python3 and used to basic but learing python.
Albert
Sun Jan 03, 2016 11:58 pm
Try
print dir(message2)
DirkS
Mon Jan 04, 2016 8:45 am
'prnt(hcm5883l)' uses this code:
	def __str__(self):
		ret_str = ""
		(x, y, z) = self.getAxes()
		ret_str += "Axis X: "+str(x)+"\n"
		ret_str += "Axis Y: "+str(y)+"\n"
		ret_str += "Axis Z: "+str(z)+"\n"
		ret_str += "Declination: "+self.getDeclinationString()+"\n"
		ret_str += "Heading: "+self.getHeadingString()+"\n"
		return ret_str
So the followings should be available:
* hcm5883l.getAxes()
* hcm5883l.getDeclinationString()
* hcm5883l.getHeadingString()
I can also see some variations that give a numrical output instead of a string:
Return to “Python”
