I am trying to find out if it is possible to call/ activate an app from within an app with Flask.
For instance, say you have app.py, which contains @app.route('/')
return render_template('login.html')
of course each containing appropriate def code etc.
So, these routes are able to call external templates/ HTML files.
is it possible to call an external python app?
I do have temps.py which calls temperatures from a ds18b20 sensor. I know I could put the code inside the main app, but would love to keep it separate and call upon it.
BTW - I will be calling the main app over LAN and Web
Any help would be appreciated,
Rainer
Re: Calling app from within app
Of course it is possible. But if the latter one is made with Python too, you could create module with it:
https://docs.python.org/3/tutorial/modules.html
- What Can a Thoughtful Man Hope for Mankind on Earth, Given the Experience of the Past Million Years?
- Nothing.
Kurt Vonnegut, Cat's Cradle
- Nothing.
enedil,
that is exactly what I was looking for!!!! TY tons!
I did read through and, after reading about module paths, understand that one can alter the sys.path to include the containing folder.
Question: if the module is in the same folder as the parent app, will the path still have to be included in the sys.path file?
Again, TY for your help - this is already very useful!
Rainer
Rainer
- elParaguayo
If it's in the same folder you don't need to do anything to sys.path.
One question, does your temperature code need to be run as root? I would think it's bad practice to run flask as root as it would create a security risk for your pi.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
very good question!
I had originally purchased DHT22's and used the Adafruit module (ah, there is the work module) but it does have to be run as root so I changed over to DS18b20's which do not. They are also water proof which I can use.
Took a while to get the code going (easy code, me inexperienced in python/Flask and had to search a bit) - but now it works
I should be able to do some trial and error this afternoon - will write back if it does NOT need a search path
TY again for your help!
Rainer
Rainer
