pageauc
sense hat rainbow.py stack smaching error
Fri Nov 13, 2015 5:02 pm
I ran the demo rainbow.py on my new Jessie imaged Raspbian RPI B2 with latest updates and upgrades. The gui desktop was disabled and the code was run from an SSH session as pi user. A sensehat is attached and was tested successfully with the various sensehat demos. I ran the rainbow.py script and left it running. When I came back after several hours the following message was displayed with no other python errors. I am rerunning to see if the problem is repeatable.
This is the console error message
pi@raspberrypi ~/sensehat $ python ./rainbow.py
*** stack smashing detected ***: python terminated
Aborted
Should this happen or is there some underlying library or code problem.
This is the code that was running
#!/usr/bin/python
import time
from sense_hat import SenseHat
sense = SenseHat()
pixels = [
    [255, 0, 0], [255, 0, 0], [255, 87, 0], [255, 196, 0], [205, 255, 0], [95, 255, 0], [0, 255, 13], [0, 255, 122],
    [255, 0, 0], [255, 96, 0], [255, 205, 0], [196, 255, 0], [87, 255, 0], [0, 255, 22], [0, 255, 131], [0, 255, 240],
    [255, 105, 0], [255, 214, 0], [187, 255, 0], [78, 255, 0], [0, 255, 30], [0, 255, 140], [0, 255, 248], [0, 152, 255],
    [255, 223, 0], [178, 255, 0], [70, 255, 0], [0, 255, 40], [0, 255, 148], [0, 253, 255], [0, 144, 255], [0, 34, 255],
    [170, 255, 0], [61, 255, 0], [0, 255, 48], [0, 255, 157], [0, 243, 255], [0, 134, 255], [0, 26, 255], [83, 0, 255],
    [52, 255, 0], [0, 255, 57], [0, 255, 166], [0, 235, 255], [0, 126, 255], [0, 17, 255], [92, 0, 255], [201, 0, 255],
    [0, 255, 66], [0, 255, 174], [0, 226, 255], [0, 117, 255], [0, 8, 255], [100, 0, 255], [210, 0, 255], [255, 0, 192],
    [0, 255, 183], [0, 217, 255], [0, 109, 255], [0, 0, 255], [110, 0, 255], [218, 0, 255], [255, 0, 183], [255, 0, 74]
msleep = lambda x: time.sleep(x / 1000.0)
def next_colour(pix):
    r = pix[0]
    g = pix[1]
    b = pix[2]
    if (r == 255 and g < 255 and b == 0):
        g += 1
    if (g == 255 and r > 0 and b == 0):
        r -= 1
    if (g == 255 and b < 255 and r == 0):
        b += 1
    if (b == 255 and g > 0 and r == 0):
        g -= 1
    if (b == 255 and r < 255 and g == 0):
        r += 1
    if (r == 255 and b > 0 and g == 0):
        b -= 1
    pix[0] = r
    pix[1] = g
    pix[2] = b
try:
    while True:
        for pix in pixels:
            next_colour(pix)
        sense.set_pixels(pixels)
        msleep(2)
finally:
    print("Exiting Program")
    sense.clear()
GitHub - https://github.com/pageauc
YouTube - https://www.youtube.com/user/pageaucp
pageauc
Re: sense hat rainbow.py stack smaching error
Fri Nov 13, 2015 10:31 pm
Well I have been running the second test for four (4) hours and still no stack smash error. Maybe a cosmic ray found the RPI. Anyway Looks like I cannot repeat the original stack smaching error. Let me know if anyone else encounters this problem. Not sure why this happened since the RPI is a very new and fresh build.
Return to “Python”
