AjitPi
Transfer .txt between two RPi (no internet,no pc)
Sat Oct 31, 2015 10:53 am
Hello friends,
I am making two systems using pi which require transfer of .txt from one pi to other, based on the received .txt i am controlling several motors. How to transfer the .txt? i cannot use internet, nor through a pc, just two Rpi. What is the easiest method? is it possible by any cable and some setup?
Basically i am looking at model where there are two Rpi and a cable between them to transfer .txt, is it possible?
(i tried reading through posts here but due to my insufficient knowledge, i am unable to follow them, please help me in simple terms how to do this, thanks)
Ajit
hippy
Re: Transfer .txt between two RPi (no internet,no pc)
Sat Oct 31, 2015 1:36 pm
Connect the two with a suitable RJ45 cable and you have a TCP/IP network allowing both to communicate with each other.
AjitPi
Sat Oct 31, 2015 4:13 pm
Thank you for ur reply, what are the setting or commands i need to perform to transfer file after connecting the cable to Rpis
klricks
Sat Oct 31, 2015 5:22 pm
AjitPi wrote:Thank you for ur reply, what are the setting or commands i need to perform to transfer file after connecting the cable to Rpis
This may help viewtopic.php?t=98652&p=685943
Or Google [connect 2 raspberry pi with Ethernet]
Does your system need to automatically transfer and process the file without user intervention?
-or-
Is it a one time or infrequent manual file transfer process?
What is the distance between the 2 RPi?
stderr
Sat Oct 31, 2015 6:01 pm
AjitPi wrote:Hello friends,
If you want to quickly get it running, look into using the ssh suite of programs. There are simple ways to copy files from one machine to another. Then the other machine can load that file and decide what to do. So there is sftp, scp, ssh, and there is also the fuse using file system sshfs. You should be able to get a basic setup going in a few minutes even just using bash and a few simple command line programs.
AjitPi
Sat Oct 31, 2015 6:20 pm
-or-
I have a button connected to one of the gpio pin , when the user presses the button a python script needs to run and send the .txt file to the second RPi.
It is not a one time activity, it has to transfer file as and when the user presses the button.
Both the RPi are in a single room, i am thinking of cable now, but once i understand and transfer files, i would venture into transferring wireless (for which i would need your help again :) )
Sat Oct 31, 2015 7:46 pm
hippy wrote:Connect the two with a suitable RJ45 cable and you have a TCP/IP network allowing both to communicate with each other.
It's marginally more complex than that. If the eth0 interface comes up active without being able to connect to a DHCP server it will get an address from 169.254.xxx.xxx (random assignment) at both ends.
You need to know the address of the remote machine to connect to it.
Sat Oct 31, 2015 8:30 pm
If they're isolated from any other network you might as well set static addresses of something 192.168.0.10 and 192.168.0.11 and then you don't have to guess.
Sat Oct 31, 2015 8:34 pm
But that's a problem if you don't have a keyboard/screen attached to each system. And when you have that it's easy to discover the pre-assigned address.
Setting a new address from a command line is trivial
sudo ifconfig eth0 192.168.1.10
it doesn't even need a netmask because the default mask is OK.
Setting a known IP address for a headless system needs an update to /boot/cmdline.txt.
AjitPi
Sun Nov 01, 2015 5:50 am
Hello thank for taking time to reply,
Can you please elaborate on what u are saying? i mean what do i exactly do?
AjitPi
Sun Nov 01, 2015 5:54 am
DougieLawson wrote:But that's a problem if you don't have a keyboard/screen attached to each system. And when you have that it's easy to discover the pre-assigned address.
So in summary ,
1. I have to connect them using the RJ45 cable
2. Then on each of them set a static IP using
3. Then?
(in this way will i be able to transfer even when i disconnect the cable then reconnect it after reboot?)
Sun Nov 01, 2015 6:27 am
AjitPi wrote:So in summary ,
Yes, but you need to give each Pi a different address. Use 192.168.1.10 for one Pi and 192.168.1.11 for the other.
3. Then?
Then you can use commands like scp to copy files from one Pi to the other. For example, to copy a file from your current folder on 192.168.1.10 to the other Pi, you would do something like
scp myfile 192.168.1.11:/home/pi
It will ask for the password for your Pi user. You can get around that fairly easily. We'll cover that later.
No, you would have to type the ifconfig commands into the Pi after rebooting. Putting the static addresses in the /etc/dhcpcd.conf files of each Pi will make them fixed.
AjitPi
Sun Nov 01, 2015 9:37 am
3. Then?
Hey, thank you very very much.. i am able to transfer the file now :) Can this same thing done throught Python script, like i give the path of the file and it is transferred to destination RPi?
(Such a helpful community! Now i will be venturing into further operations confidently :) )
Sun Nov 01, 2015 9:41 am
AjitPi wrote:
So in summary ,
3. Then?
On rpi #1
On rpi #2
sudo ifconfig eth0 192.168.1.20
AjitPi
Mon Nov 02, 2015 3:31 am
Thank you very much for the solution, please let me know what is the simplest setup for wireless transfer for the the same problem?
ame
Mon Nov 02, 2015 3:33 am
AjitPi wrote:Thank you very much for the solution, please let me know what is the simplest setup for wireless transfer for the the same problem?
Install USB wifi dongles in each Pi.
Set up one Pi as an access point.
Set up the other Pi to connect to it.
Your other software is the same, since an IP network with wifi is the same as a wired IP network.
AjitPi
Mon Nov 02, 2015 8:26 am
Thank you Ame! I will try that wifi thing.
Before that i am stuck in one thing, i have a wired ethernet now and using scp to copy files from one to another. But it is asking for password everytime i transfer
1.I want to disable password, how to disable it?
2. How do i do all this activity through python script? i want to just give the path and press a button to transfer file.
Thank you, please reply i am in need of this kind of urgently :(
Mon Nov 02, 2015 8:58 am
AjitPi wrote:Thank you Ame! I will try that wifi thing.
First step, on both Pis make sure you have a .ssh directory
pi@raspi5 ~ $ mkdir .ssh
(don't worry if it says "mkdir: cannot create directory `.ssh': File exists", that means it has already been done)
Then create some private and public key files on each Pi
pi@raspi5 ~ $ sshkeygen -t dsa
Just press Enter for any questions it asks.
Add the public keyfiles to the other Pis list (do this for both Pis, changing the IP address.
pi@raspi5 ~ $ ssh 192.168.1.11 'cat >>.ssh/authorized_keys'  < .ssh/id_dsa.pub
(pi@raspi5 is the account on one of my Pis. It will be 'pi@somethinglese' on yours)
After that it shouldn't ask you for a password again.
Good question. I don't use python. I think it has something called "system" that can be used to run commands. Probably some examples on the forum.
elParaguayo
Mon Nov 02, 2015 9:29 am
Use the "subprocess" module (this is recommended in place of using os.system that you'll also see people using).
My experience of scp is light but, if I recall, the format for copying a local file to remote is
scp /path/to/local/file user@address:/path/to/remote/file
If so, doing this in python would be:
from subprocess import call
local_file = "/path/to/local/file"
remote_user = "user"
remote_address = "address"
remote_path = "/path/to/remote/file"
remote_destination = "{}@{}:{}".format(remote_user, remote_address, remote_path)
cmd = ["scp", local_file, remote_destination]
call(cmd)
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
AjitPi
Mon Nov 02, 2015 12:12 pm
call(cmd)
Thank you very much rpdom!! that works when i manually type scp command!!
but when i run scp through python script , it asks for password again :(
@elParaguayo : can you please help too
elParaguayo
Mon Nov 02, 2015 12:35 pm
That seems odd.
Googling for python and scp, I've seen a few suggestions of using subprocess.Popen rather then subprocess.call.
I don't see any reason why this should make a difference but try:
from subprocess import Popen
... rest of code ...
#call(cmd)
proc = Popen(cmd).wait()
# proc will have the return code from the command once it's finished.
AjitPi
Mon Nov 02, 2015 4:16 pm
I wil try this out tomorrow morning, its late night here :(
i will let you know after this
elParaguayo
Tue Nov 03, 2015 9:25 am
Actually, I wouldn't bother trying it!
Looking at the source code for the subprocess module, subprocess.call(cmd) is just a shortcut for subprocess.Popen(cmd).wait(). So my suggestion above won't make any difference.
AjitPi
Mon Nov 09, 2015 5:09 am
Ya the command still asking for password when i do it through python script :(
is there a way that i enter the password through the script when it asks for? i am exploring pexpect but cant find how to exactly write the code and use it
Mon Nov 09, 2015 5:36 am
I don't understand why it would ask for the password when run from a python script instead of running from the command line. :?:
Oh... hang on... are you running the script with sudo? If so, the scp command will be run from the root user, not the pi user. It'll be using the credentials in /root/.ssh/ instead of /home/pi/.ssh/
Return to “Python”
