phaze3131
MQTT Python Script Errors
Mon Oct 19, 2015 1:12 am
I'm running this python script to set my Rpi as a broker, accept clients who want to change the LED status on the Rpi breadboard.
Just confused about errors I get when I execute the script.
Here are the errors:
mqttlight.py:23: RuntimeWarning: No channels have been set up yet - nothing to clean up! Try cleaning up at the end of your program instead!
GPIO.cleanup() # clean up resources
File "mqttlight.py", line 63, in <module>
client = paho.Client(client_id=MQTT, protocol=paho.MQTTv31)
NameError: name 'MQTT' is not defined
Thanks for any help!
Re: MQTT Python Script Errors
Mon Oct 19, 2015 7:55 am
Since we can't see the code you're running we can't help.
Try posting it here wrapped in [code]...[/code] tags.
You need to install and run mosquitto as your MQTT broker before running any client programs.
Massi
Mon Oct 19, 2015 3:45 pm
phaze3131 wrote: client = paho.Client(client_id=MQTT, protocol=paho.MQTTv31)
You are giving a client_id that you did not define when connecting to the broker
"client_id is the unique client id string used when connecting to the broker."
You can avoid using it (when clean_session is true), but if you want to use it for sure you need to define it :)
danjperron
Mon Oct 19, 2015 3:55 pm
Massi is correct
I use paho and my line is
client = paho.Client('RFUnit')
You will have to previously set the variable MQTT to an ID string.
ex: MQTT='MyMqttClient'
phaze3131
Mon Oct 19, 2015 9:27 pm
I'm not sure how it got changed but that error line 63 was wrong and I changed it back to how the code reads below.
client = paho.Client(client_id=random_client_id, protocol=paho.MQTTv31)
After this change to the correct 'random_client_id string, the error went away.
So sorry about not posting the full code.
import paho.mqtt.client as paho
import RPi.GPIO as GPIO
import json, time
# device credentials
device_id        = 'admin'      # * set your device id (will be the MQTT client username)
device_secret    = '313131'  # * set your device secret (will be the MQTT client password)
random_client_id = 'MQTT'      # * set a random client_id (max 23 char)
# Board settings #
buttonPin = 7
ledPin = 12
GPIO.setmode(GPIO.BOARD)  # use P1 header pin numbering convention
GPIO.setup(ledPin, GPIO.OUT)   # led pin setup
GPIO.setup(buttonPin, GPIO.IN)   # button pin setup
# Callback events #
# connection event
def on_connect(client, data, flags, rc):
    print('Connected, rc: ' + str(rc))
# subscription event
def on_subscribe(client, userdata, mid, gqos):
    print('Subscribed: ' + str(mid))
# received message event
def on_message(client, obj, msg):
    # get the JSON message
    json_data = msg.payload
    # check the status property value
    print(json_data)
    value = json.loads(json_data)['properties'][0]['value']
    if value == 'on':
        led_status = GPIO.HIGH
        GPIO.output(ledPin, GPIO.HIGH)
    else:
        led_status = GPIO.LOW
        GPIO.output(ledPin, GPIO.LOW)
    # confirm changes to Leylan
    client.publish(out_topic, json_data)
# MQTT settings #
# create the MQTT client
client = paho.Client(client_id=random_client_id, protocol=paho.MQTTv31)  # * set a random string (max 23 chars)
# assign event callbacks
client.on_message = on_message
client.on_connect = on_connect
client.on_subscribe = on_subscribe
# device topics
in_topic  = 'devices/' + device_id + '/get'  # receiving messages
out_topic = 'devices/' + device_id + '/set'  # publishing messages
# client connection
client.username_pw_set(device_id, device_secret)  # MQTT server credentials
client.connect("178.62.108.47")                   # MQTT server address
client.subscribe(in_topic, 0)                     # MQTT subscribtion (with QoS level 0)
# Button logic #
prev_status = GPIO.LOW
updated_at  = 0  # the last time the output pin was toggled
debounce    = 0.2  # the debounce time, increase if the output flickers
# Continue the network loop, exit when an error occurs
rc = 0
while rc == 0:
    rc = client.loop()
    button = GPIO.input(buttonPin)
    if button != prev_status and time.time() - updated_at > debounce:
        prev_status = button
        updated_at  = time.time()
        if button:
            led_status = not led_status
            button_payload = 'off'
            if led_status == GPIO.HIGH:
                button_payload = 'on'
            # effectively update the light status
            GPIO.output(ledPin, led_status)
            payload = { 'properties': [{ 'id': '518be5a700045e1521000001', 'value': button_payload }] }
            client.publish(out_topic, json.dumps(payload))
print('rc: ' + str(rc))
Return to “Python”
