YouKidsGetOffMyLAN
Help on email at bootup
Wed Oct 07, 2015 11:51 pm
Hello! I recently puchased a raspberry pi.
I already have a vnc server running for use without a monitor.
Right now im trying to setup a script that will allow me to send myself an email with the Pi's ip address
following this guide:
http://elinux.org/RPi_Email_IP_On_Boot_Debian
I never recieve a email upon startup. Running the program itself replies with
pi@raspberrypi ~/Code $ sudo python startup_mailer.py
  File "startup_mailer.py", line 46, in <module>
    split_line_b = ip_lines[2].split()
IndexError: list index out of range
I have been trying to solve this now for a few hours with no luck.
Google is letting me down on this one. Does anyone have expirence with this
setup? Any input with be appriciated.
arg='ip route list'  # Linux command to retrieve ip addresses.
# Runs 'arg' in a 'hidden terminal'.
p=subprocess.Popen(arg,shell=True,stdout=subprocess.PIPE)
data = p.communicate()  # Get data from 'p terminal'.
# Split IP text block into three, and divide the two containing IPs into words.
ip_lines = data[0].splitlines()
split_line_a = ip_lines[1].split()
pi@raspberrypi ~/Code $ ip route list
default via 192.168.0.1 dev wlan0  metric 303
192.168.0.0/24 dev wlan0  proto kernel  scope link  src 192.168.0.103  metric 303
elParaguayo
Re: Help on email at bootup
Thu Oct 08, 2015 12:19 pm
Well, I can see why you're getting the error: the script expects (at least) 3 lines to be returned by "ip route list" but it's only getting two so you get an error when it tries to access the third line.
The problem is I don't know what "ip route list" should be returning and why that 3rd line is important? If your IP address was the "192.168.0.103" in the second line then the code could be changed to get the value.
EDIT: Looking at the code, I think this is just looking for two network interfaces but you've only got one. You could therefore edit the code to just look at the first network interface, or, if you're feeling adventurous, change the code so it can handle 1 or more interfaces.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
suneetagera
Fri Dec 11, 2015 4:23 am
Faced the same issue, saw the resolution .... changed my code accordingly. Works great. Thanks.
Fri Dec 11, 2015 8:50 pm
Try this
#!/usr/bin/python3
import time
from datetime import datetime
import smtplib
from email.mime.text import MIMEText
from email.mime.image import MIMEImage
from email.mime.multipart import MIMEMultipart
import socket
import os
testIP = "8.8.8.8"
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect((testIP, 0))
ipaddr = s.getsockname()[0]
host = socket.gethostname()
f_time = datetime.now().strftime('%a %d %b @ %H:%M')
toaddr = 'example@gmail.com'    # <== CHANGE ME
me = 'example@gmail.com'       # <== AND ME
password = 'redacted'            # <== AND ME
subject = 'IP address for '+ host + " at "  + f_time
msg = MIMEMultipart()
msg['Subject'] = subject
msg['From'] = me
msg['To'] = toaddr
msg.preamble = "Test message @ " + f_time
message = "Current IP: " + ipaddr
html = "<html><head></head><body><h1>Your IP address</h1><p>Your Raspberry has IP address: "+ ipaddr + "</body></html>"
plainText = MIMEText(message, 'plain')
htmlText = MIMEText(html,'html')
msg.attach(plainText)
try:
   s = smtplib.SMTP('smtp.gmail.com',587)
   s.ehlo()
   s.starttls()
   s.login(me,password)
   s.send_message(msg)
   s.quit()
except smtplib.SMTPException as e:
   print (str(e))
   print ("Error: unable to send email")
Return to “Python”
