RogerW
os.getlogin() fails under Jessie
Tue Sep 29, 2015 4:04 pm
I do not know if this should be in the Rasbian forum. If I start python from the command line os.getlogin() works. However if I run in the GUI (startx) it fails, even in a command window. The error says 'No such file or directory'.
PeterO
Re: os.getlogin() fails under Jessie
Tue Sep 29, 2015 4:07 pm
I suspect a relative path or something similar in your code ! Show us the whole error message and the code you are running.
PeterO
RogerW
Tue Sep 29, 2015 4:17 pm
Sorry but I don't know how to get a screenshot from the pi ont my PC. It works if I putty (SSH) into the pi.
Start idle (or idle3) and then
>>>import os
>>>os.getlogin()
plugwash
Tue Sep 29, 2015 4:22 pm
https://bugs.debian.org/cgi-bin/bugrepo ... bug=743500
says
os.getlogin() is almost never what you want. The documentation says[0]
that “for most purposes, it is more useful to use the environment
variable LOGNAME to find out who the user is, or
pwd.getpwuid(os.getuid())[0] to get the login name of the currently
effective user id.”
RogerW
Tue Sep 29, 2015 4:32 pm
Interesting but that is unix only. getlogin() works in Windows. What really puzzled me is why it works from a command line but not under X.
PeterO
Tue Sep 29, 2015 8:47 pm
RogerW wrote:Interesting but that is unix only. getlogin() works in Windows. What really puzzled me is why it works from a command line but not under X.
I confirm it doesn't work under X on Jessie but does work in a console.
PeterO
Return to “Python”
