RPi Adafruit 16x2 LCD Internet Radio - Python Script error
Posted: Tue Sep 01, 2015 10:50 am
Hello All,
I've been tinkering with the Pi and scouring the net for hours trying to solve this and I'm stumped so I've come here hopefully for some assistance (
I'm trying to build an internet radio following this guide http://www.instructables.com/id/Raspber ... /?ALLSTEPS
It was all going ok until i tried to actually get the Radio scripts to work with the LCD.
I know that I2C is working because the example .py script that cycles colours on the screen and lets you test the buttons works fine.
I know that MPD and MPC work because I can get a stream to play if I run it direct from the command line.
BUT when I run what I assume is the main radio script 'radio.py' I get this error:
Googling around, popular opinion seems to be that this is a problem with the I2C not being enabled, but as the example script works fine I can only assume its something else. I have no experience of Python and so I'm struggling with deciphering this error.
I'd really appreciate some help with this, as I bet there are loads of folks that have had a crack at this project!
Cheers
pi@raspberrypi ~/radio $ sudo python radio.py
['mpc', 'stop']
mpc stop --> ['volume:100% repeat: off random: off single: off consume: off']
File "radio.py", line 385, in <module>
Radio().run()
File "radio.py", line 267, in __init__
Adafruit_CharLCDPlate(),
File "/home/pi/radio/Adafruit_CharLCDPlate.py", line 81, in __init__
self.i2c = Adafruit_I2C(addr, busnum, debug)
File "/home/pi/radio/Adafruit_I2C.py", line 36, in __init__
busnum if busnum >= 0 else Adafruit_I2C.getPiI2CBusNumber())
IOError: [Errno 2] No such file or directoryI'd really appreciate some help with this, as I bet there are loads of folks that have had a crack at this project!
Cheers
