friendl
Learn Python 2 or 3?
Tue Jul 28, 2015 9:31 pm
Hi all,
I've been reading from various resources online, one tells me to stick to Python 2, the other Python 3 for it's the future.
What do you recommend for programming on the R'Pi?
friendl
Re: Learn Python 2 or 3?
Tue Jul 28, 2015 9:42 pm
A follow up, a bit more searching, found this useful guide on 2 vs 3:
https://wiki.python.org/moin/Python2orPython3
Looks like learn 3 makes more sense if you're new to the language.
metalj
Tue Jul 28, 2015 9:47 pm
Your probably going to learn both. Most books are 3 and codecademy is 2. It seems like you have to choose but the only thing you have to do is stick with it till the end of your lessons.
Backspace 28 times :)
paddyg
Wed Jul 29, 2015 8:24 am
There used to be quite a few modules that hadn't been converted from 2 to 3, but in Apr 2014 (when the doc in you link was last updated) it was a small proportion - significantly smaller now!
As you have just discovered the python2 v python3 issue is an annoying confusion with an otherwise very good language. It's probably time that all python advocates started giving a clear "3" in answer to your question. And hasten the demise of python2!
elParaguayo
Wed Jul 29, 2015 8:44 am
paddyg wrote:As you have just discovered the python2 v python3 issue is an annoying confusion with an otherwise very good language. It's probably time that all python advocates started giving a clear "3" in answer to your question. And hasten the demise of python2!
Yes, I think that's probably the right answer too.
However, it's useful to understand both and their differences especially if you want to adapt someone else's (older) code which was written in python 2.
Personally, I've never used python 3 but that's because I got into to python in order to write addons for XBMC/Kodi and they had to be python 2. So my hand was forced, but I have no regrets and have yet to come to a situation where I've needed python 3 (but maybe that's just because I haven't been adventurous enough yet!).
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
