RogerW
Scrolling graph using tkinter
Fri Jul 24, 2015 11:05 am
I have been playing with a scrolling graph object. So far it works but lacks axes and legends. As new data points are added the trace scrolls left to right. More than one trace can be shown. Performance depends on the speed of updates, the width of the graph and the number of traces. The test program works well on a pi2 but a bit slower on a pi B+
This file contains the graph object (graph.py)
# graph.py
# class to show a moving graph
# written by Roger Woollett
from sys import version_info
if version_info[0] < 3:
    import Tkinter as tk
else:
    import tkinter as tk
class Trace():
    # class to represent a single trace in a ScrollGraph
    def __init__(self,master,max_x,min_x,colour,size):
        self.master = master
        self.size = size
        self.scale = master.height/(max_x - min_x)
        self.offset = -self.scale*min_x
        # create a list of line ids
        self.lines=[]
        i = 0
        while i < master.width:
            self.lines.append(master.create_line(i,0,i,0,fill = colour,width = size))
            i += 1
    def scroll(self,value):
        # scroll to the right and add new value
        value = self.scale*value + self.offset
        # we want positive upwards
        value = self.master.height - value
        # do scroll
        i = self.master.width - 1
        while i > 0:
            x = self.master.coords(self.lines[i - 1])
            self.master.coords(self.lines[i],i,x[1],i,x[3])
            i -= 1
        # add new value
        self.master.coords(self.lines[0],0,value,0,value + self.size)
class ScrollGraph(tk.Canvas):
    # class to show a scrolling graph
    def __init__(self,master,*args,**kwargs):
        tk.Canvas.__init__(self,master,*args,**kwargs)
        self.width = int(self['width'])
        self.height = int(self['height'])
        self.traces = {}
    def add_trace(self,name,max_x,min_x,colour = 'black',size = 1):
        # call to add a trace to the graph
        self.traces[name] = Trace(self,max_x,min_x,colour=colour,size = size)
    def scroll(self,name,value):
        # call to add a new value to a trace
        self.traces[name].scroll(value)
This file contains the test program
# trygraph.py
# test program to try out the graph class
else:
import graph as g
from math import sin,pi
DELAY = 20  # time period for generating dada points
class Mainframe(tk.Frame):
        tk.Frame.__init__(self,master,*args,**kwargs)
        # create the scroll graph
        self.graph = g.ScrollGraph(self,width = 300,height = 100)
        self.graph.grid(row = 0,column = 0)
        # add a thick red sine wave trace
        self.graph.add_trace('sin',1,-1,'red',size = 3)
        self.angle = 0
        # add a thin green saw tooth trace
        self.graph.add_trace('saw',100,0,'green')
        self.saw = 0
        self.inc = 1
        # add a quit button
        tk.Button(self,text = 'Quit',width = 15,command = master.destroy) \
        .grid(row = 1,column = 0)
        # start the process of adding data to traces
        self.dodata()
    def dodata(self):
        # add data to both traces
        self.graph.scroll('sin',sin(self.angle))
        self.angle += 0.05
        if self.angle >= 2*pi:
            self.angle = 0
        self.graph.scroll('saw',self.saw)
        self.saw += self.inc
        if self.saw == 100:
            self.inc = -1
        if self.saw == 0:
            self.inc = 1
        # call this function again after DELAY milliseconds
        self.after(DELAY,self.dodata)
class App(tk.Tk):
    def __init__(self):
        tk.Tk.__init__(self)
        self.title('Try Graph')
        Mainframe(self).pack()
App().mainloop()
Anybody interested? Constructive comments welcome.
[EDIT] I should have said to put both files in the same directory.
tonywaite
Re: Scrolling graph using tkinter
Fri Jul 24, 2015 9:56 pm
Thank you for sharing this.
I can't test it for a fortnight, but look forward to using it as a template.
RogerW
Sat Jul 25, 2015 8:18 am
tonywaite wrote: I can't test it for a fortnight, but look forward to using it as a template.
Do let us know how you get on.
racpi
Sat Jul 25, 2015 1:03 pm
thanks for sharing this ,it was the next thing to do on my pi learning curve .
works just fine python 2.7 on win7 machine too
davef21370
Sat Jul 25, 2015 3:10 pm
Just tried on my laptop and works fine, not got a use for this yet but will definitely keep hold.
Dave.
Apple say... Monkey do !!
racpi
Wed Nov 25, 2015 2:19 am
hi roger
just got around to using your code for a scrolling barometer display , works great.
did you get anywhere with legends/axis info, ticks etc ?
else:
import os
import datetime
import sqlite3
import graph as g
DELAY = 600000  # time period for generating dada points
        pd = str(datetime.datetime.now() - datetime.timedelta(hours=34))
        conn=sqlite3.connect('/media/CORSAIR/wh3.db')
        curs=conn.cursor()
        self.graph = g.ScrollGraph(self,width = 200,height = 200)
        self.graph.add_trace('b',1040,900,'green',size = 3)
        self.graph.add_trace('baro',1032,990,'red')
        #curs.execute("        SELECT data,ts from wh where ts >= '"+base+"' order by ts asc  ")
        for row in curs.execute("SELECT mslp,ts FROM house WHERE    ts >='"+pd+"' order by ts asc   "):
            d=row[0]
            self.graph.scroll('baro',d)
            self.graph.scroll('b',1008)
##            print row
        self.lastread=row[1]
        conn.close()
        # add a quit button
        self.dodata()
    def dodata(self):
        # add data to  traces
        curs=conn.cursor()
        pd=self.lastread
        for row in curs.execute("SELECT mslp,ts FROM house WHERE    ts >'"+pd+"' order by ts asc   "):
            if row != None:
                d=row[0]
                print row
        conn.close()
class App(tk.Tk):
    def __init__(self):
        self.title('mslp Graph')
App().mainloop()
RogerW
Wed Nov 25, 2015 9:52 am
I am afraid I did not get much further. I did add an X axis with ticks but that is all.
# trygraph.py
else:
from graph import ScrollGraph,XAxis
        self.graph = ScrollGraph(self,width = 300,height = 100)
        self.angle = 0
        self.saw = 0
        self.inc = 1
        # add x axis
        XAxis(self,30,10,height = 10,width = self.graph.width,size = 2) \
        # add a quit button
        .grid(row = 2,column = 0)
        self.dodata()
    def dodata(self):
        self.angle += 0.05
            self.angle = 0
        if self.saw == 100:
            self.inc = -1
        if self.saw == 0:
            self.inc = 1
class App(tk.Tk):
    def __init__(self):
App().mainloop()
# graph.py
else:
class Trace():
        self.size = size
        self.lines=list()
        i = 0
            i += 1
        # do scroll
        coords=self.master.coords
        while i > 0:
            x = coords(self.lines[i - 1])
            i -= 1
        # add new value
        self.traces = dict()
class XAxis(tk.Canvas):
    # class to show horizantal x axis with ticks
    def __init__(self,master,big,small,size = 1,*args,**kwargs):
        self.create_line(0,1,width-1,1,width = size)
        # do small ticks
        i = small
        while i < width:
            self.create_line(i,1,i,height/2,width = size)
            i += small
        # do big ticks
        i = 0
        while i < width:
            self.create_line(i,1,i,height,width = size)
            i += big
RogerW
Wed Nov 25, 2015 10:08 am
Sorry - I just found out that the code in my reply is out of date.
If you look at
https://github.com/RogerWoollett/PyView
the graph.py there has a Y axis as well.
You might find PyView of interest. It has scrolling views for memory and cpu usage.
Return to “Python”
