Ivan219
Running VNC
Tue Jul 07, 2015 10:44 am
Hello, I learned, that XRDP open a new session every remote connection. And then I learned that VNC do only one session. But I can't run it. I run in console:
sudo apt-get install tightvncserver // No erros
pi@raspberrypi ~ $ sudo vncserver :1 -geometry 1024×768 -depth 16 -pixelformat rgb565
vncserver: geometry 1024×768 is invalid //ERROR
I install UltraVNC Viewer, and typed to ip-box: ip_of_rasspberry:1 , But connection failed.
How resolve it?
davef21370
Re: Running VNC
Tue Jul 07, 2015 12:14 pm
Try 1024x768 (lower case letter X).
Dave.
Apple say... Monkey do !!
Ivan219
Re: Running VNC
Tue Jul 07, 2015 12:33 pm
I resolve problem with resolution. I read instruction from: https://www.raspberrypi.org/documentati ... ccess/vnc/, I install and run VNC, but I can't connect to raspberry by tightvnc: error in tightvnc viewer a connection attempt failed because target computer rejected the connection, how connect to VNC?
Ivan219
Re: Running VNC
Tue Jul 07, 2015 9:58 pm
I resolve VNC connect problem, but VNC make new session, and how I can make one (same) session? (For example: I control mouse from remote VNC and from mouse usb raspberry.
AndyD
Re: Running VNC
Wed Jul 08, 2015 12:21 am
Ivan219 wrote:I resolve VNC connect problem, but VNC make new session, and how I can make one (same) session? (For example: I control mouse from remote VNC and from mouse usb raspberry.
To control the desktop on the Raspberry Pi using VNC your best option is to use x11vnc, rather than tightvnc.
Ivan219
Re: Running VNC
Wed Jul 08, 2015 11:39 am
I install x11vnc, next I write: x11vnc -display :0 -usepw -noxdamage -ncache 10 -ncache_cr -listen IP_of_pi -allow allowed_ip_address
But I can't connect to raspberry by UltraVNC Viewer, I write: ip:0, but no connection. How resolve this problem?
kusti8
Re: Running VNC
Wed Jul 08, 2015 12:10 pm
Try connecting with:
IP:5900
Ivan219
Re: Running VNC
Wed Jul 08, 2015 12:49 pm
Unfortunately, not working.
Ivan219
Re: Running VNC
Wed Jul 08, 2015 5:48 pm
I resolve it! Thank you)
elParaguayo
Re: Running VNC
Wed Jul 08, 2015 8:11 pm
Ivan,
Can you please post your solution so that anyone else who has this problem can see how you managed to get it working.
elP
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Joe Schmoe
Re: Running VNC
Wed Jul 08, 2015 8:26 pm
elParaguayo wrote:Ivan,
elP
Usually, when someone just posts "I solved it!" - with no details - it is because they realized they did something stupid and they just wish the whole thing would go away...
Ivan219
Re: Running VNC
Thu Jul 09, 2015 3:41 pm
Sorry, that I did not write directly. I resolve problem with do all steps in instruction again, I think problem was that I close console window, and try to start VNC remote.
Return to “Python”
