Looking at the source code again, if the "with" method didn't work for you, you should probably call the "destroy" method when you're finished:
Destroy the device. This method destroys the device file and closes the underlying file descriptor. This method must be called exactly once for each created device.
The code would look like this:
import time
import uinput
def main():
events = (
uinput.KEY_E,
uinput.KEY_H,
uinput.KEY_L,
uinput.KEY_O,
device = uinput.Device(events):
time.sleep(1) # This is required here only for demonstration
# purposes. Without this, the underlying machinery might
# not have time to assign a proper handler for our device
# before the execution of this script reaches the end and
# the device is destroyed. At least this seems to be the
# case with X11 and its generic event device
# handlers. Without this magical sleep, "hello" might not
# get printed because this example exits before X11 gets
# its handlers ready for processing events from this
# device.
device.emit_click(uinput.KEY_H)
device.emit_click(uinput.KEY_E)
device.emit_click(uinput.KEY_L)
device.emit_click(uinput.KEY_O)
device.destroy()
if __name__ == "__main__":
main()
If that gives an error, just remove the "device.destroy()" line.
