Peter-Jan
steppermotor user control
Thu Jun 18, 2015 11:47 am
hello guys,
im working on a project where i need to control steppermotors via a raspberry pi the steppermotors do work but my question is how do i get user control so if i do w it go's forward for example.
this is the code im using at the moment:
# Import required libraries
import time
import RPi.GPIO as GPIO
import random
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
# Define GPIO signals to use
# Pins 11,12,13,15
# GPIO17,GPIO18,GPIO27,GPIO22 for motor X1
# GPIO23, GPIO24, GPIO26, GPIO4 for motor X2
# Motor X1 achteruit
StepPinsX1B = [22,27,18,17]
# Motot X1 vooruit
StepPinsX1 = [17,18,27,22]
# Motor X2 vooruit
StepPinsX2 = [23,24,25,4]
# Motor X2 achteruit
StepPinsX2B = [4,25,24,23]
# Set all pins as output
for pin in StepPinsX1:
  print "Setup pins X1"
  GPIO.setup(pin,GPIO.OUT)
  GPIO.output(pin, False)
for pinX in StepPinsX2:
  print "Setup pins X2"
  GPIO.setup(pinX,GPIO.OUT)
  GPIO.output(pinX, False)
# Define some settings
StepCounter = 0
WaitTime = 0.1
# speed up
Up = "u"
# direction back
Back = "b"
# direction left
Left = "l"
# direction right
Right = "r"
# Define simple sequence
StepCount1 = 4
Seq1 = []
Seq1 = range(0, StepCount1)
Seq1[0] = [1,0,0,0]
Seq1[1] = [0,1,0,0]
Seq1[2] = [0,0,1,0]
Seq1[3] = [0,0,0,1]
# Define advanced sequence
# as shown in manufacturers datasheet
StepCount2 = 8
Seq2 = []
Seq2 = range(0, StepCount2)
Seq2[0] = [1,0,0,0]
Seq2[1] = [1,1,0,0]
Seq2[2] = [0,1,0,0]
Seq2[3] = [0,1,1,0]
Seq2[4] = [0,0,1,0]
Seq2[5] = [0,0,1,1]
Seq2[6] = [0,0,0,1]
Seq2[7] = [1,0,0,1]
# Choose a sequence to use
Seq = Seq2
StepCount = StepCount2
# Start main loop
try:
  while 1==1:
    for pin in range(0, 4):
      xpin = StepPinsX1B[pin]
      if Seq[StepCounter][pin]!=0:
        print " Step %i Enable %i" %(StepCounter,xpin)
        GPIO.output(xpin, True)
      else:
        GPIO.output(xpin, False)
    for pin1 in range(0, 4):
      xpin1 = StepPinsX2[pin1]
      if Seq[StepCounter][pin1]!=0:
        print " Step %i Enable %i" %(StepCounter,xpin1)
        GPIO.output(xpin1, True)
      else:
        GPIO.output(xpin1, False)
    StepCounter += 1
# If we reach the end of the sequence
# start again
    if (StepCounter==StepCount):
      StepCounter = 0
    if (StepCounter<0):
      StepCounter = StepCount
#   toets = input()
#   print (toets)
#    if toets = "s"
#      print (toets)
#    WaitTime = (WaitTime+0.1)
#    else print (WaitTime)
  # Wait before moving on
    time.sleep(WaitTime)
except Up:
       print "u is pushed"
       WaitTime = (WaitTime-0.5)
       print (WaitTime)
except KeyboardInterrupt:
  GPIO.cleanup()
davef21370
Re: steppermotor user control
Fri Jun 19, 2015 7:02 pm
Google "PyGame events", you can catch keyboard input whilst in a loop handling other stuff.
Dave.
Apple say... Monkey do !!
Peter-Jan
Mon Jun 22, 2015 7:45 am
oke thank you
Return to “Python”
